Tv cuts on and off by itself
When trying to turn on tv it just keeps cutting on and off by itself. Samsung says there is a problem and has an update but since tv will not stay on it can not be loaded. Samsung said basically that we are out of luck since the tv is 14 months old. Any help would be greatly appreciated.
  • 4 Answers
SOURCE: my samsung dlp tv model hl-p5063 w cuts off multiple times while playing
Hi, I had the same problem on my Samsung.
I removed the rear cover and cleaned the cooling fans, there were (2), it has worked fine ever since.
Be careful of course working with electrical boards.
Posted on Dec 01, 2007
circuitcity
  • 137 Answers
SOURCE: picture cut off
check your picture default settings. It may be set to Zoom, If not check your Cable box setting. Press settings and go to picture size. Make sure its set to Normal or Stretch.
Best regards
CircuitCity
Posted on Dec 06, 2007
Coldcut
  • 1554 Answers
SOURCE: Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Posted on Mar 08, 2008
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
SOURCE: 42" panasonic viesta plasma tv cuts off after about 30 minutes
Adjust the automatic shut off settings on the set using the menu system. the newer models are programmed to shut down to avoid the burn-in problem associated w/ plasma scenes.
Posted on Dec 30, 2008
My samsung tv sound keeps cutting out. I have to
either you have a loose connector going to speakers or the main board is failing.call 1-800-samsung for nearest service center.
Dec 02, 2009 | Samsung LA40A450 40 in. LCD TV
My tv keep cutting itself off. I will have to
It could be going into power saving mode. Check your settings.
Hope this helps.
Iain
Oct 14, 2009 | Computers & Internet
Why do my tv keep cutting off by itself?
check your tv if the timer is on..if the timer is on,off it..
Jul 28, 2008 | Symphonic ST420FF 20" TV
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
E900 keeps cutting out
Cutting out as in the person on the other end of a call is dropping, or the phone is turning itself off.
Call dropping problems are usually signal strength issues, affected by location, phone model, the mobile network your connecting too, the charge on the battery.
Phone randomly turning off is general a handset fault. return for warranty repair
Dec 22, 2007 | Samsung SGH-E900 Cellular Phone
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
