Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
The refrigerator will not stay cold. The freezer gets as cold as 44 degrees.
  • Kenmore Master
  • 4,654 Answers
I believe you most likely have a defrost problem. Look inside rear of freezer and see if there is a lay of frost building up on rear wall or floor, depending on what model you have it could most likely be the defrost timer or adaptive defrost. I need your Sears number that looks like this foe example 231.56489 on the bottom of fresh food door frame behind door seal and near floor kick plate. Your next most likely reasons will be defrost heater or defrost thermostat. If you find frost I want you to unplug and begin manual defrost. Remove rear panel of freezer after unplugging and use a hair dryer. That will give you a little time to see the problem and get answers to repair them, Sea Breeze
Posted on Sep 13, 2009
Have a Kenmore side by side refrigerator freezer gets cold but refrigerator side stays at 40 degrees
The refrigerator of fresh food side is supposed to be around 40 so its working correctly.
Feb 27, 2015 | Kenmore Refrigerators
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
How cold should the freezer get?
I am assuming you are referring to Fahrenheit.. 16 is a little warm for a freezer. They usually stay around zero to 10 degrees above or below.
Sep 14, 2014 | Samsung Refrigerators
Freezer works but fridge doesn't stay cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer not freezing anymore, refrigerator is not as cold. Barely cooling anymore
I hope you find the answer. I have the same problem. I have a 4.5 year old Whirlpool Gold side by side and the Freezer tops out at 30 degrees and refrigerator at 44 degrees. I paid $216 today for a control board by a "local Factory Authorized Service Agent" and the temperature has not budged one bit since the repair 4 hours ago. I called the service company and he told me the refrigerator had to "stabilize" and I should see a difference tomorrow. I'm not holding my breath!
May 09, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Ice build up in freezer and temp in fridge section not very cold
just needs to be defrosted ice is blocking the vent for the bottom defrost it and should be good
Aug 28, 2009 | Samsung RF265AA Bottom Freezer French Door...
Refrigerator cools, but not cool enough, even with temp adjustment turned to coldest setting. Freezer only gets down to 0. Fridge at 44 degrees
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 06, 2009 | Refrigerators
The refrigerator is not staying cold
Check it's cealing of the door. Depends if it's cooling and then not staying cold, means door is not cealed or frequency of opening too much. More possibility is gas leakage.
Mar 04, 2009 | Frigidaire FRS26ZSG
New used refrigerator
HI thanks for your question. a fridge takes at least 24 hrs to get cold and cycle give it some time. the gurgling is normal its the freon boiling in the freezer. its normal. thanks the appliance doc. please rate my answer. thanks.
Jun 19, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
91 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
