Question about Keurig B70 Coffee Maker
Slow coffee stream with k-cup, very strong stream when no k-cup
We have had 5 keurig coffee makers, the last 3 have all had the same problem, very weak stream with k-cup installed, very strong stream without k-cup
    President:
  • 1,273 Answers
It may not be the machine, but, rather the pods. I have had occasion where the problem was the sme, and the k-cups were heavier than normal when removed, as though there was a manufacturing problem particular to that particular type of k-cup. Try a variety of different k-cups and see if this can be narrowed down to one particular brand. My issue was with the Kona type, and it was limited to some cups in one box. The only other thing I might suggest would be to check that th opening from the pod to you coffee cup is open by passing a wire through it.
Best regards,
--W/D--
Posted on Sep 13, 2009
When using the my k cup, i get water coming down in 3 streams.I have to hold the coffee cup up so that the coffee hits the cup
The bottom needle is plugged...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 22, 2011 | Keurig Elite B40 Coffee Maker
Keurig Coffee Maker Elite: Coffee is showering instead of streaming into my cup and is going onto my countertop. I cannot make a cup of coffee without this happening. Thanks for any help.
The bottom needle is plugged....Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
heatman101
Aug 05, 2011 | Keurig B60 Coffee Maker
My keurig coffee maker dose not fill cup..ex..small..med..lg..very little water comes out..makes coffe super strong
heatman101
May 28, 2011 | Keurig B60 Coffee Maker
My keurig coffee maker is flashing the words DE SCALE. What does that mean and how do I fix it?
"Scale" is deposits of minerals, etc. normally found in water. Boiling a container of water (in a pot, or coffee maker in this case), leaves small amounts or "deposits" of these minerals on and near the actual heat source. If not removed, they can slow brewing time and more importantly, adversely affect the taste of coffee.
Descaling should be done at regular intervals to prevent this from happening. Your machine lets you know when to perform the descaling task. There are a number of products sold in your supermarket that will do this for you - but one of the least expensive; and just as effective - is to use white vinegar. Here's how to do it:
1) Drain your Keurig coffee machine over a sink.
2) Fill the machine with undiluted white vinegar.
3) Run the brew process at least four times, pouring the cups of vinegar back into the coffee maker.
4) Optionally, let your Keurig coffee maker sit for a few hours, then run the brew cycles again. Pour the vinegar into the sink and drain any remaining vinegar.
5) Fill your coffee maker with fresh water. Run multiple brew cycles with fresh water each time to thoroughly rinse the machine before returning to normal use.
That's it!
I know this will help & good luck. Please rate my reply - thanks!
Feb 06, 2011 | Keurig Ultra B50 1-Cup Coffee Maker
Weak Coffee
Yep, it's the one inherent flaw in the single serve machines - someone else decides what 'the perfect cup of coffee' tastes like.  Quite presumptuous, actually.
Solution I found to be acceptable:  Buy only the extra bold flavors (there's about 5 or 6 varieties) and brew using the small cup size button.  Yes, you only fill your mug about 3/4 of the way, but at least you get a decent cup of coffee.
The ONLY flavor I found to be strong enough when brewing with the large cup control button is DOUBLE BLACK DIAMOND...the rest is crap.
Dec 27, 2007 | Keurig B50 Coffee Maker
Keurig B70 Coffee Maker Logo
673 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
