Question about Refrigerators
Outside of freezer hot
Freezer is hot on the outside and inside is not freezing cold enough
  • Mike Smith
    Mike Smith May 11, 2010
    Check the coils at the bottom of fridge to make sure they are clean . Also , check the fan motor behind the refrig , which cools the compressor , to make sure it is working .
  • 4,059 Answers
Make sure the condenser fan underneath where the compressor is, is running.
Posted on Sep 13, 2009
I just replaced my automatic ice maker in my Samsung french door refrigerator. Now the temperature is not cold enough to freeze the water which leaves the ice bucket with water not ice. Freezer works
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
This is the heat you feel blowing near the freezer when it's in a cooling cycle. ... Also, using a freezer to cool hot items or opening the freezer frequently will ... If you noticewater pooling on the floor when the freezer is running but not freezing, ...
Why Is My Freezer Not Cold Enough? - Articles - Networx
www.networx.com > ... > Electrical > Appliance Repair > Read Article
Sep 1, 2011 - Next, make sure the freezer isn't overloaded and that the evaporator fan ... are choked with frost, restricting the airflow that makes the freezer cold. ... In verycold weather, a freezer in the garage may heat up, since there isn't enough warm ...unit (even on automatic-defrost units, in case there's a lot of water).
refrigerator - Freezer is cold but not freezing at all - Home ...
Dec 20, 2015 | Refrigerators
Bought an upright Frigidaire Freezer on Craigslist and the inside gets cold and works like a champ but the outside side panels get very hot- is this normal or is there a short?
If there is a short circuit, the circuit breaker protection in your house wiring would trip (Open the electrical circuit path).
It is normal for the condenser, which is on the outside of the appliance to be hot because it is transfering the heat from inside the freezer cabinet to the ambient air outside the cabinet. Make sure that you give the appliance enough space all around the hot condenser so that it can transfer its heat to the surrounding air efficiently.
P.S. Some freezer designs integrate the condenser coils into the metal cabinet, thus the hot side panels.
Aug 28, 2011 | Frigidaire 14 cu. ft. / 396 liter Upright...
Freezer will not freez ,warm air
replace temp sensor, should work also first check drain pipe some time gets blocked.same symptoms...
Feb 07, 2010 | Refrigerators
Red light is on on bottom panel and buzzer is going off. Inside temp is 20 degrees and outside temp is 25 deg
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Not all refrigerators are insulated the same and not all condensers are in the same place. Your cold control is monitoring the temperature of the refrigerator section and is designed to turn off the compressor to keep things from freezing in that section. If it stays cold long enough outside in your garage the cold control thinks its cold enough and won't turn the compressor on. A makeshift closet to hold a little heat the unit generates will probably help.
Jan 06, 2010 | Freezers
Is it normal for the outsides to get very hot
No. If you feel the sides getting hot, it usually means that the ref. isn't cold enough inside. There us either an electric heater or a pass of the hot gas from the compressor around the edges of the doors as well as the mullion between them. If they feel hot, it's too warm inside.... Check the ice cream: It's the 1st to go.
Oct 25, 2009 | Frigidaire Freezer Refrigeration White...
Stuff in the freezer is melting, motor is running, no cold
turn your freezer temp dial to off and wait 30 seconds, then turn it back on to max setting. if you have temp gauage you can try to check temp inside freezer, if not cold enough (less than 30 degrees) you could be losing freon gas. you need to call technician.
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The frizer outside is very hot. kenmore model 71192107 year7/02
The condensor coils run around , up , down , the sides of the freezer . This heat is the heat being pulled OUT of the inside , which makes the freezer cold . Freon (refrigerant) attracts heat , which causes the frost in refrigeration . But , the heat has to dissapate , otherwise , hot gas would pump thru the system , and , no cool . A freezer does not get cold , Heat is pulled out , causing food to freeze . So , hot is good .
Aug 01, 2009 | Refrigerators
Chest freezer repair
I had the same problem with an upright and so I bought a piercing valve and charged the compressor with 134R and has been working great since.
Jul 05, 2009 | Freezers
Freezer
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
Sep 15, 2008 | Freezers
Not getting cool enough
try moveing the thormister up in the refer it is on the right hand side of refer inside refer box if this does not help use a fan and blow it tru outside vent on low
Jun 23, 2008 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
190 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
