Question about Refrigerators
Model 106.5703600 side by side, not making ice. I've checked it over, and think I've got adequate water pressure. Still getting water from dispenser, but no water to ice trays.
    President:
  • 1,136 Answers
Hi, The first thing you want to check is the inlet tube that sticks through the rear wall of the freezer section. These inlet tubes plug up with ice quite frequently. If the tube is plugged with ice, thaw the ice inside the tube and then replace the inlet valve. The inlet valve will leak water when they get older and cause the water to freeze in the inlet tube.
Please let me know if this helps you at all or if I can assist you further.
Thanks
VIc
Posted on Sep 13, 2009
My new refrigerator's ice maker and water dispenser doesnt work
Since this is a brand new unit, I wouldn't waste the time or money troubleshooting it yourself; contact the place you purchased it from and exchange it.
Jul 14, 2008 | LG LSC26905TT Side by Side Refrigerator
We have a jenn-air jfc2087hrs (french door model) and the water pressure from the internal water dispenser is very low. the line has plenty of pressure.
If your ice maker is making full size cubes then it should one of 2 problems.
The water valve on the bottom back of the machine is a dual valve. One side feeds the ice maker, the other side feeds the water supply.
1. The dual water valve. is going bad. The water side is malfunctioning.
The dual valve must be replaced.
2. Your model should have filters for the water dispenser, and need replaced.
Try changing the filters first.
Oct 04, 2009 | Jenn-Air JFC2087HRS Side by Side...
Ge fridge makes Ice, doesn't dispense
turn freezer side to zero for 1 minute. press water dispenser
Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Quit making ice
hi there,check the line and the inside of the freezer door for any ice issues. can you also check the ice bin to see if there is any ice in it?
please also provide me with the model # off your fridge?
Sep 09, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Water dispenser presure
change yo wata valve on bak o frige
then u will smile friend
Jun 19, 2008 | Whirlpool GD5SHAX Side by Side...
Jenn air Mdl#jcd2389ges Very slow water dispenser
You will probably find that if you have a water filter in your model refrigerator that is is clogged. Replace the filter and voila, good flow again. You probably also have small or hollow or chip ice cubes as well, if your filter is clogged.
To save the cost of the filter you would need to check to make sure you are getting strong water flow to the solenoid valve located in the bottom rear of your refrigerator.
I hope I helped, supertechks
Mar 27, 2008 | Jenn-Air JCD2389G Side by Side...
Leaking icemaker
It sounds like your water valve is occasionally get stuck open and over filling the icemaker.
Oct 29, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Water/Ice Dispenser is not working
Some models need the filter inplace to pass water. First check it again with a new filter in just to be sure the filter isn't clogged. Next... do you hear any click or such noise from the rear of the unit when you push the water dispenser? The solenoid valves may be bad. Also check the valves at the back of the frige to see if the filter screen isn't clogged blocking water from getting into the frige all together. Let us know what you find and post again.
Dec 20, 2006 | Amana ASD 2624 Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
