Question about RCA F19207BC TV
I have a circa 1998 RCA F19207BC (XL100 Commercial Skip), and the picture is almost entirely black. The only way to see anything at all is to turn "Black level" and contrast all the way up, and in doing so the picture looks terrible. Is the TV busted, or is there a control that I'm not seeing? I've seen a few other posts about this (or a similar?) TV mention two knobs (focus & brightness) on the back right side, but my TV doesn't have these. Thanks!
SOURCE: Commercial Skip Feature
When a commercial comes on, you press the "Commercial Skip" button on the remote. Then you see a 30-second countdown timer appear on the screen. If you think there will be more than 30-seconds of commercials, then press the button more (each time you press adds 30 seconds to the on-screen timer -- usually I press it 4 to 5 times). The timer stays counting down on the screen while you change channels during the commercials to see what else is on. When the timer counts down to 0, it is erased from the TV screen and the TV automatically changes you back to the channel it was on when you pressed the commercial skip button. I use this feature a lot! I wish all TV's had it built in. Some universal remotes have a similar (but more awkward feature) where the remote has the timer inside it, and it sends a signal back to the TV when the count is up, but I don't think this would work as well.
Posted on Mar 20, 2008
jerryg50
  • 1667 Answers
SOURCE: RCA XL100 Commercial Skip won't turn on
The power supply or one of the circuits that it is feeding has a short in it. It may be able to be serviced by someone who knows the product and is experienced at working on the model you have. There may be a question about parts availability for it.
You can call RCA to find out who the authorized service rep is for your area. This is something that most small TV service stores may not be able to repair.
Ask for an estimate before approving service. The repair for your unit may be expensive.
Jerry G.
Posted on Apr 16, 2008
gopakumarg43
  • 74185 Answers
SOURCE: i have a rca xl100
Hello
To unlock RCA TV, try the following.
Most RCA TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Posted on May 14, 2011
  • 5123 Answers
SOURCE: Looking for tv manual for RCA XL100 F19207BC
I found two different manuals for the RCA XL100 F19207BC using the RCA manual search (http://www.rca.com/tvsupport/tv_manual_search.php ) The direct links are: http://download.rca.com/FilesForRCAcom/Manuals/1512765B.pdf and http://download.rca.com/FilesForRCAcom/Manuals/15127650.pdf .
I hope this helps.
Posted on May 22, 2011
Slinteriors
  • 8617 Answers
SOURCE: RCA D56W20, Works OK, so long as the "black level"
The green CRT has an issue and will need to be replaced. It could be the Green CRT drive board but doubtful as your describing the classic sign of a CRT thats developing a Short . You can get replacement green CRTs and CRT drive boards from www.tvrepairworld.com
Posted on Oct 15, 2011
Rca xl100 commercial skip tv
There is no other way to unlock it, without its original remote control. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too.
http://electro-medical.blogspot.com/
Gopakumar Gopalan Google
Mar 10, 2014 | Televison & Video
CODE FOR RCA XL100
use the search button on the remote with the tv on.. wait until you are able to turn it off with the remote..
Feb 02, 2014 | Proscan PS27113 TV
RCA XL 100 f19207bc menu button wont work
The front panel control buttons should be checked. Contact any service technician.
Oct 15, 2013 | Televison & Video
MANUAL for RCA XL100 F19207BC Television
The official RCA XL100 F19207BC manual can be located HERE
Alternatively, you may type
in your web browser to access the document from RCA's Consumer Television Customer Service website.
May 22, 2011 | RCA Televison & Video
RCA XL100 20" Snow on screen
you have lost one of 3 things,Antenna/Cable, Tuner or part of your tv's power supply
Sep 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Jerry G.
Apr 16, 2008 | Televison & Video
RCA XL100 Remote Code?
I found a remote on the web for that model and purchased it.
Apr 11, 2008 | RCA Universal Remote Control
Black screen...no color
On the back of the set, look for 2 controls labeled focus and screen. If the TV is working but you cannot see the picture, try turning the screen control up little by little and the brightness should come back. If this works then make sure the focus control is set so that the picture is nice and sharp.
Jun 16, 2007 | RCA F19207BC TV
My t.v.
probebly The picture tube is defective, the green gun is shorted, Its a common problem Its not something you can fix alone
Mar 29, 2006 | RCA F19207BC TV
RCA F19207BC TV Logo
128 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
