Question about Eljer 018-6000-00 White Gibraltar Soaking Tub 018-6000
New tub chipped
I just bought a Eljer tub at Home Depot and when painting above it dropped the brush and the tub chipped! We are very disaqppointed and wonder if there is a fix.
    President:
  • 1,273 Answers
Most tub manufacturers sell a repair kit specifically for their brands, and usually are the best solution for repairing chips and dings. I would attempt to get their kit if it is available first. Normally, they are provided free of charge for damage discovered after installation, and at reasonable cost for owner inflicted damage. If such a kit is not available, you may have to "wing it"
Here are three possibilities, and I have used two of these.
If your tub is enamel on iron/steel, and you have the chipped out piece, you can reattach it with matching enamel (appliance) touch up paint as the adhesive, and it works as the crack filler as well. Reinstall the chip, and sand smooth after drying with auto wet sand paper, beginning with 800 grit and take it progressively to 1500/2000 grit, until the gloss matches the surrounding surface. This makes an invisible repair.
If the chip is in acrylic, you can repair with a fibreglass repair kit available at one of the home hardware type stores. Again, it is better if you can re use the chipped out piece. If it is available, mix the repair parts of the kit together and butter it into the groove (after trial fitting the chip). Place the chip back into place, and cover with wax paper. Weight the chip to keep it in place until it dries, and wet sand as before. This makes a "close to invisible" repair.
A better repair to acrylic can be made if you can grind some matching surface acrylic (gel coat) to dust and mix the dust with the fibreglass repair resin before re-installing the chipped piece. This makes a closer surface match, leaving the resin surrounding the chipped piece less noticeable. All of the materials used for this type of repair are compatable
If the chipped piece is not available, you can harvest a small piece from an out of view section to make the dust/filler and apply as a paste, filling the chipped area flush and sand smooth as before. This takes the artist's eye to get exactly right, but it can be done. If you cannot get a harvested piece from your own tub, you may be able to get a piece from the store where you bought the tub. If they have a damaged/returned tub, they will usually "donate" a small piece to help you out. I have seen returned tubs be sold for salvage prices.
Just as reference for future use, it is a good idea to cut a plywood cover for the tub, or to line it with cardboard when remodeling to prevent having these type of repirs added to your list of things to do. I learned this a while back, the hard way.
Best wishes. Hope that this was of some use to you.
--W/D--
Posted on Sep 13, 2009
Bath tub paint
www.homedepot.com/b/Paint.
Any Two part epoxi paint will work
Feb 19, 2014 | Eljer Plumbing
Where can I BUYold eljer bathtub drain plug
Try Home Depot or your local hardware store. Or eBay.
Feb 17, 2014 | Plumbing
I am home this weekend and I decided to paint my living room. Is there an amount of coats that you are needing to put on the wall? It has been a while sense I have painted. I heard maybe about 3 to be...
if the existing paint is a light color and you are doing the same color, then 2 coats should suffice,. Painting it darker, I would go 3 coats, painting it lighter, you may need to go more than 3 go to harbor freight tools and buy some plastic drop sheets, masking tape {blue} and some cheap brushes and roller and tray, turn on some tunes and a glass of wine, enjoy the "me time" depending on the quality of paint too will determine the coats needed, ask your home depot guy. behr brands are good cover paints. good luck have fun.{ps..wear some old clothes}
Oct 15, 2013 | Corel Paint Shop Pro 9
Need reviews on Eljer Whirlpool Triangle Tubs. Eljer a Good Tub to Buy?
Eljer is owned by Jacuzzi Whirlpool. Very nice tub. Eljer is one of the bigger Bathtub Mfg out there.
Not sure why he has not heard of them. Lowes is probably the biggest seller of that brand.
Rod
US Parts Center
Feb 07, 2013 | Eljer Triangle WP 60x60 LH 10JT
Hi, I have a light grey corner Eljer 1 6 gpt/6lpf (?) toilet and the seat has a big scratch in it. It is not the same color throughout... Looks like particle board under paint. Where can I buy a...
Sorry to read about your problem, I hope this helps you out.
this will not be found at home depot..best to go online at eljer www.eljer.com
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Eljer Triangle Emblem Corner Toilet -...
The toilet comes with a hard body flapper which utilizes a pretty straight-forward gasket. The gasket material failed within 3 months. The Korky that I purchased will not function properly. Impossible to...
We have just recently purchased one of the American standard cadet at home depot from a discount flyer and had it for about a day and took it back.
We Did not notice Any thing like a strong flush.
RECOMENDATION:
Take it back.
Home Depot sells a Kohler Toilet 1.6 Gallon Flush Install
This is all it said it was. It saves water for sure and has a quick flush.
We liked it so much we purchased two of them because everyone in the house only wanted to using our bathroom.
Hope this tip helps
David
Feb 21, 2010 | Eljer TOILET RND IN BOX WHT -...
Installing whirlpool tub
If it is a five foot tub, home depot usually carries them, if not any plumbing supply store will have them.
Jun 22, 2009 | Eljer Home
How to Change White Water Whirlpool Tub Jet Hardware
I recommend that you consider spray painting the gold hardware with brushed nickel rusteoleum paint. IF you decide to go this route you must lightly abrade the gold surface with emery cloth then prime with rusteoleum primer, let that dry and the final coat will be the brushed nickel. I have done this and it turned out excellent. I get compliments on it.
Regarding your other issues, you will be happiest with white water parts. That being said, it is likely that locally procured parts might fit. I would get one set of parts and try them.
You will likely find the model number etc. on a plate in the mechanical compartment of the spa.
May 28, 2009 | Kohler 1107-R-0 ProFlex Bath Tub with...
Non-slip surface is dirty, discolored
I would try tilex. Be sure to spray it on and let it sit for 15 minutes before you start scrubbing. Use an old fashioned scrub brush on a handle so you can stand and put some leverage into it. If one application doesn't do it, repeat until you have it the way you want it. good luck
Jan 23, 2009 | Whirlpool Safety Bath Walk In Bathtub -...
Eljer 018-6000-00 White Gibraltar Soaking Tub 018-6000 Logo
192 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
