Question about Poulan Garden
Engine will not pick up fuel - Poulan Garden
    Brigadier General:
  • 4,088 Answers
Remove the fuel line (check condition) from the carburetor body, tip the engine up so that the fuel tank is a little higher than the fuel line end--fuel should run out. Does this unit have a primer button? If so, inspect for holes or cracks in the clear button and the condition of the two hoses attached to it. Remove the carburetor from the engine and inspect for a hard or cracked diaphragm and pumper valves (disassemble the carburetor). Clean with spray carburetor cleaner and re-kit it if you found bad parts. Install the H and L mixture screws to CW stops (lightly) and back out to 1-1/2 turns each. This should allow the engine to run. Warm up the engine, pull the throttle full on, and adjust the H screw until the engine just starts running at high speed with cutting line deployed at full operating length. Drop back to idle and adjust L for smooth idle, but still allow the engine to 'follow the throttle'. Adjust idle speed high enough to keep it running.
Posted on Sep 13, 2009
Engine having trouble getting enough fuel because it does not pick up speed
How do you know it is not getting enough fuel? Any lean codes set? Backfiring? There could be many other reasons it will not pick up speed such as leak in the hose from MAF to throttle body, bad TPS, bad coil/module. If it is fuel starved, change fuel filters and test pressure while driving.
Feb 16, 2015 | 2003 Pontiac Grand Am GT
1999 vw passat wont start starter tunn engine turn but engine not pick up
First you need to figure out if the problem is fire or fuel.check for spark if you have spark next check for fuel getting to the engine
Jun 07, 2012 | Volkswagen Passat Cars & Trucks
My nissan b14 engine holds back when the transmission changes during the acceleration process. urgently needs a solution.cars picks up good one moment and when the second gear is selected, the cars...
Is fuel pump working properly ?- sounds like you may have a case of fuel starvation under certain situations. Check for pressure being within specs.
Aug 24, 2017 | 1996 Nissan Sentra
2001 Chevy s10 4.3 surges and won't pick up speed. Valves rattle when you mash accelerator to the floor and it smells like its flooding out
You want to start with the knock sensor, located on the side of the block, about 1 1/4 inches in diameter, 1 1/2 inches long. funny looking sensor. It is suposed to pick up knocks/pings in the engine and tells the ECM to advance or ****** the engine. Check the engine for codes, even if the light is not on. Let me know we can go from there
Randy
Feb 24, 2011 | 2001 Chevrolet S-10
My 1991 toyota pick ,will start but shut off ,
I would check out the Mass Air Flow Sensor. Located on top of the air filter box. If the sensor is bad and computer doesn't see air going into the engine, it will automatically keep the engine from running. Try pulling the engine trouble code to confirm is problem.
Oct 11, 2009 | 1991 Toyota Pickup
91 ford mustang 5.0 fuel pump and relay is working but the pump is not getting power
How do you know the fuel pump is not getting power?.The fuel pump only comes on for a second or two before cutting back off.The ecm only suppys power to the relay for a few short seconds with key in the on position.Only constant 12 volts is supplied when the engine is running.Is the fuel pump new?How do we know it is good?Also is the engine giving a spark when the engine is turning over?If the engine has no spark,then the pick up coil could be bad,otr the ignition module could be bad.Check the fuel at the injsctors or a fuel line to see if the fuel will pump out when the key is turned on,if it does not,then check to see if the ijectors are pulsing.If the injectors are not pulsing ,and you have spark,then remove the distributor and replace the pick up coil,and the ignition module.The pick up coil,along with the igniyion module give the injectors there pulse.One other thing,If the fuel pump is not for sure coming on,check to see if the relay is clicking on,and then off in a couple of seconds.If this is true,then replace the fuel pump.Any other questons,please ask,I will try to help if I can.I hope this was some help,let me know,thanks.
Sep 29, 2009 | 1991 Ford Mustang
How can we check the ignitor and coil ? what are the specs?
What engine do you have? You could still hear your fuel pump running but if you haven't checked the fuel pressure you may still have a problem with your fuel pump. You should be around 38 to 44 PSI when key is turned on not running. Did you verify you are getting spark or is there nothing to the plugs? Your ignition coil resistance should be (cold 9000-15,400 ohms) Primary should be .36-.55.
Your pickup coil resistance depending whether you are California or excluding California
California is
cold- pick up coil terminals G1 & G- Ohms 125-200
cold-Pick up coil terminals G2 & G- Ohms 125-200
cold-Pick up Coil terminals NE & G- Ohms 155-250
Ex. California models
cold-Pick up coil terminals G+ & G- Ohms 185-275
Cold-Pick up coil terminals NE+ & NE- Ohms 370-550 ohms
You also need to check air gap between PIck-up Coil & Signal rotor
California is .008-.020
Except California .008-.016
Here are some of the suggestions from Mitchell books:
ENGINE CRANKS BUT FAILS TO START:
*Ensure proper spark exists from ignition system
*Ensure Fuel system performs properly (fuel pump, Fuel filter, Fuel injectors, fuel pressure regulator).
*Check engine compression, valve clearance, valve timing and timing belt (if equipped)
Check airflow meter or MAP sensor and wiring
*Check idle air control valve (if equipped) and wiring.
*Check circuit opening relay and EFI main relay.
*Check STA signal at Engine Control Modual (ECM)
*Check Engine Control Modual (ECM) and wiring.
Aug 04, 2009 | 1995 Toyota Camry
Low pick on uphill slope and low pick up with AC too
hello sir.
low pick up on uphill and low pick up with AC ON.
these both r general physics problem, due to the higher downforce on uphill the car will b having low pick up. n with AC 'ON' the AC will b using a part of fuel supply engine, hence with higher power on the AC, larger is the fuel sucked from the engine supply. hence the lesser is the fuel supply top the engine, thus low power output.
i requst u to please check your car performance with the car of same type, on the sane road, by yourself, then conclude that your car is not performing,
it happens with the age of the car too, with long run, ur car cluthes will b damaged, ur carborator, with low tire pressue, with low quality radiator oil, ur car engine may rise the temperature, thus reducing this power output.
surely their is no problem with your car.
a general check up with a local mechanic will surely fix it sir.
thank u .
if my soultion helped u, then plz give me a feedback.
Jul 15, 2009 | 2005 Hyundai Santa Fe
Car loosing power and engine management light coming on computer picking up as high fuel pressure.
might want to check your fuel pump and adjust the fuel presure throwing to the engine,pumping to much fuel will cause it to choke.
Sep 18, 2008 | Honda Accord Cars & Trucks
Ran truck out of gas, got gas still will not start
happened to my girl's malibu- kept putting gas in it- didnt help. kept jumping it to be sure- didnt work either. turns out it was the fuel pump...... very annoying. hope that might help a little.
Aug 08, 2008 | 2001 GMC Sonoma Extended Cab
Garden Logo
155 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
