Question about Kodak EasyShare V570 Digital Camera
The camera doesn't open and it doesn't charge. It is dead.
The camera doesn't open and it doesn't charge. Even with a new rechargeable battery it still does not do anything. It doesn't light up when I put it on the charger. It was working until all of a sudden it just wouldn't open up and I thought it just needed charging but when I put it on the charger it didn't even light up or do anything.
  • 3 Answers
I wonder if you attached the right voltage of charger.
Thats what I did. I put on a 9v dc charger
Now my v570 is dead......but ironically it will still charge a battery.
Now an expensive battery charger!
Posted on Oct 20, 2009
CAMERA WILL NOT POWER UP EVEN WITH FULLY CHARGED BATTRIES
Try non-rechargeable batteries, and try testing your rechargeable batteries because they do wear out.
Sep 19, 2014 | Cameras
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
Hp photosmart M23: can I charge new batteries in the camera
The batteries can be recharged in the camera with the appropriate adapter or dock. See page 155 of the manual.
Oct 17, 2012 | Cameras
Install new charged rechargable batteries and will be dead batteries in bout 2 hrs not even turned on. take 2 pics and gone
Is your newly charged battery are new? Maybe your battery is worn out already. Or buy a new rechargable batteries and observe. Remember do not over charge your battery, this is always the reason why your battery got easily worn out. Thanks
Sep 11, 2011 | Kodak EasyShare C875 Digital Camera
I got the kodak easy share 143 model camera coming brand new off of ebay yesterday,,,but it keeps saying my batteries are half drained, then dead after a couple of photos. Then if they're dead it...
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 26, 2011 | Kodak Cameras
Battery Dont Charge
I had the same problem. I had a 1 year warranty, so I called 1800-435-7732 and they sent me a new battery within 5 days. I just received it today and it works perfectly. Hope this helps you! =]
Dec 26, 2008 | Casio Exilim EX-Z77 Digital Camera
Kodak easy share c 340
try taking out the batteries, and clean the connectors that the batteries touch, and the ends of the batteries (if recharagable). Sometimes a dirty connector can make the batteries seem that they are dead even if they are rechargable. If the camera works with new disposable batteries but not with the rechargable ones, then you may need to purchase some new rechargable ones.
Oct 23, 2008 | Kodak EasyShare C340 Digital Camera
Dead batteries when fully charged
Does it work with "no batteries" - only plugged into power source? check your usb cable by trying to power up something else.
Jun 28, 2008 | Fuji FinePix S7000 Digital Camera
Low battery warning
It's something with the camera. I have the same camera and the same problem. I bought 2 brand new batteries, charged them, and the very first thing the camera did when I installed the new batteries was tell me that they were dead!! Grrr....
As a workaround, when it tells you the battery is dead, just open the battery door, close it, and try again. Repeat if necessary. With my camera, doing this lets me use the same battery for days and days. The battery is NOT dead - it's just a faulty warning message.
Apr 18, 2008 | Canon PowerShot SD10 / IXUS I Digital...
Kodak EasyShare V570 Digital Camera Logo
119 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
