Question about Metabo WE14-150 Quick Angle Grinder
Magnetic brush size
Is there a difference in the size of Magnetic brushes between the 4 1/2 and the 6" Metabo angle grinders?
  • wfay May 11, 2010
    There are slight differences in brush sizes and types, but without a model number to cross reference I cannot be certain.
  • David Ford
    David Ford May 11, 2010
    I dont think there would be but without both model numbers I don't know. If you can give them to me I will do more research
    Problem Solver:
  • 10 Answers
Yes and no. From 1999 to early 2008, excluding the slightly beefier "Ergo" models, the size / part number is the same. However, on the newest models there are differences in density between some models. Wire placement is different from the older models.
Posted on Sep 29, 2009
  • Ike Sep 29, 2009
    BTW, they are not magnetic.
Sparks are coming from my metabo w6-115 angle grinder where the bushing are and it seems to be grinding a bit
There are always some sparks with power tools from the brushes.
You should remove the brushes for inspection to check wear.
Be sure to reinstall in the same direction.
Jul 16, 2011 | Metabo 06204 4 1/2" 900W Ang Grinder
Where can i buy some brushes for my grinder
try "ereplacementparts.com" you will need the information that you provided here to look up the schematic and then the brushes.
Jun 18, 2011 | Metabo 606405470 W21-230 9" 6,000 RPM 15.0...
No power to bite
Needs new brushes. http://www.metabo.com/Spare-parts-lists-handheld.16913.0.html
When the brushes wear down they are held back by there power wires.There should be a set of small holes in the brush holders.Push new brushes to the bottom and put a wire through the small holes to hold brushes in place during reassembly.Pull out the wires and the new brushes will seat. Brushes don't cost all that much.
May 07, 2011 | Metabo GE700 Grinder
I need help to replace my brushes on a makita 9553NB 4 inch angle grinder the old model i used to have had easy access.. coin sized slots on the handle that you simply uncsrew to reveal the brushes. my...
first unplug the tool, next on the backside you will notice a screw, remove it and slide the cover back to expose the backside of the motor. gently move the springs that hold the brushes tight to the side and remove the brushes and replace. Make sure to replace the springs and then slide the cover back into place and replace the screw and that should take care of your problem.
Feb 18, 2011 | Makita 9553NB 4" Angle Grinder
Grinder runs about 2 minutes then shuts off. I replaced the heat sensor- no change. What else could be the problem?
check the condition of the brushes, make sure not sticking in the brush tube and also look at the commutator for a really dirty surface.
Dec 21, 2010 | Metabo 01451 We14 150 Quick Electronic 6...
I had been using this grinder for about 2 weeks with no problems. A few days ago while using it it just popped and hasn't worked since.
These are great grinders. I have two of them. One version (more expensive one) has soft start and good overload system. Other version is basic grinder. if it (popped) most likely a short in the motor. Is it possible you got an unusual amount of grinding dust into the grinder? This grinder has a safety feature on the brushes, that keeps from burning up the armature when the brushes wear out. I doubt you've worn out a set of brushes in 2 weeks, unless you've been using it non stop. At least one of the brushes has a small plastic insulating pin inside the carbon. When the brush wears down enough to expose the plastic pin, the spring loaded pops out, lifting the brush from the armature , which opens the circuit. You could remove the brush holders and inspect the brushes. If it is 2 weeks old it is under warranty, and you should return it where you bought it.
Jul 14, 2010 | Metabo ® 12 Amp 9000 RPM Model WE14150...
Where can I find brushes for MAKITA 9557PBX 4
The brushes for that grinder are Makita Part #194074-2. They can be found on sites like www.ereplacementparts.com.
Mar 31, 2010 | Makita 9557PBX 4 1/2" Angle Grinder with...
Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Sep 15, 2009 | Metabo WE14-150 Quick Angle Grinder
Just replaced the brushes in a Metabo WE14-150Quick Angle grinder
when you replaced the brushes did you notice the tool throwing sparks? Generally when I work on these after replacing the brushes I have to clean the commutator to seat the new set. You could also have other problems, e.g. bad brush holder (did you replace as assembly or just brush) Let me know what happened to the first set and if when you plug in and try it does it come up to full speed.
Sep 12, 2009 | Metabo WE14-150 Quick Angle Grinder
Metabo WE14-150 Quick Angle Grinder Logo
140 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
