Question about Cameras
I have the same problem
It makes a clicking sound and trys to retract. It won't even go into PC mode. I have taken it apart and sprayed it with compressed air and nothing seems to work.
In your battery compartiment is a small cover labeled CR1220.
PLEASE READ MANUAL on how to open it.
Behind that cover you will find a coin shaped battery, provably type CR1220.
PLEASE READ MANUAL on how to remove it.
Get a replacement battery (watch store/ camera store/...)
PLEASE READ MANUAL on how to install it.
Power on camera, set date and time and DONE!
Posted on Sep 13, 2009
  • MegaMad
    MegaMad Sep 13, 2009
    I don't know; this solution ended up on the wrong question...
Water
This ac unit will have to be taken apart and clean out the drain holes in the bottom of the case.Use a water hose to clean and wash it out,also remove any large objects by hand,of course you will have to remove the unit from the window to do this.
Apr 16, 2012 | DeLonghi PAC C120 12000 BTU Portable Air...
2002 xj6 2.5 turns over trys to start but won't
if car has been sitting idle for a period of more than 7 days fuel looses its octane strengh/ batterry could be low test it - Make sure timing is accurate and try spray into carbaretor direct before strart with WD 40 or such like product to direct fuel feed to spark 0k
Jan 31, 2012 | 2002 Jaguar X-Type
I have a Westinghouse 505E dryer and it won't
if its making a buzzing sound the motor is stuck its proberly full of lint it need taken apart and vac out around the motor / or it could be motor bearings worn or the belt brocken you will need to take apart to hav a look
Dec 09, 2011 | Dryers
1990 240 wagon won't start. Just makes a single click sound. All the battery lights and everything else works.
check your connections at the battery,clean any corrosion and tighten.(baking soda and warm water works.wear gloves and safety glasses)
if still clicks when trying to start,it probably your solenoid on your starter.
check connections there or while someone trys to start it tap side of starter with a pc of wood or small mallet.
Oct 07, 2011 | 1990 Volvo 240
My lights, windows, and radio all work fine. But it won't start it makes a click noise but nothing. Then we thought it was the battery so we jumped it and now it won't even make no click noise at...
The "click" sound condition make us guess that could be a bad ignition switch or starter.
It turned out to be the starter. I first took the battery to have it tested and it was fine. Next, I took the starter apart and took it to Autozone to have it tested? and it was bad. It is not easy access to remove the starter. The intake manifold and exhaust system are in the way and need to be taken apart first. See instructions below:
- Take off Intake
- Take off Starter
Hope this helps (remember to rating this answer and leave some comment).
Sep 28, 2011 | 2003 Honda Element
Disc table does not open or close - stuck open
Hello the unit is out of timing now, it will have to be taken apart and retimed. You have skipped some gear tracks and the unit will not close until the Tray is realigned. Try hitting the eject button so the tray comes all the way out then pull on it gently to see if it realigns it self. When it trys to go back in it is hitting the clamper because the tray has not reached home and the clamper that gasps the disk is closing before it has a chance to return home.
Nov 30, 2009 | Pioneer BDP-95FD Blu-Ray Player
The lens is stuck 1/2 way out and I am unable to access the menu and have taken the batteries out and even replaced them.
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Oct 30, 2009 | Nikon COOLPIX L18 Digital Camera
Tape will not retract
Sounds like the carrage is out of time with the deck. Either that or the mode switch (the switch that senses the location of all the gears on the deck) is in need of an internal cleaning. When the contact pads on the mode switch get a little corroded it will confuse the microprocessor that controls loading and it will not know where the gears really are. Good luck.
Mar 30, 2006 | JVC GR-D250 Mini DV Digital Camcorder
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
