Question about Bunn Cuisinart Coffeemaker: Pour-Omatic Coffee Brewer ( O Matic)
Saeco Magic Roma - Steam & Water OK, no Coffee
I have a Saeco Magic Roma machine, which is not working correctly. When the coffee button is depressed, it grids no worries, puts the coffee grounds into the brew group. The motor then activates to turn the brew group into the next position, but i think it is running slow, not making it to the point it lifts and seals and therefore the water is never activated to run through the coffee. The motor then reverses back to the N position like it has completed its cycle. No fault indicators are present.
Not sure if the issue is the motor / solenoid which rotates the brew group, or if something is jamming and not allowing it to rotate freely.
    President:
  • 1,618 Answers
Remove brew unit and push on bottom end shaft you will hear a snap then turn and lift small bar lever ( if you are holding unit with handle towards you it will be on the right side), this will help you see if there is an obstruction.
Posted on Sep 16, 2009
How to ventilate Saeco Magic Comfort + coffe maker
Hi
If its a Magic Comfort + there is a water button on the panel (with the drop) that you push for water. You twist the dial for steam only.
If its a Magic Delux you twist the dial for water.
Nov 21, 2010 | Saeco Magic Comfort Plus Espresso Machine
JUST HAD IT SERVICED. RAN TWO SHOTS OF ESPRESSO, STEAMED MY MILK JUST FINE. THEN WHEN I TRIED TO DO ANOTHER SHOT, PUSHED BUTTON AND NOTHING HAPPENED. STEAM LIGHT FLASHING, WON'T GO OFF.
Hi
If you steam and then try to make another coffee, you need to cool the boiler off. Turn the steam off by pushing the steam button again, then open the steam knob and running water until the flashing light turn to green steady. Then make you coffee.
Sep 10, 2010 | Saeco Magic De Luxe Espresso Machine
My saeco magic coffee machine says ventilate.How do I do this?
Hi
If it is just a Magic Delux, open the steam knob, without pushing the steam button. If its a Magic Comfort you have to push the button with the drops on it and it will flow water.
Apr 10, 2010 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Jun 12, 2009 | Saeco Magic De Luxe Espresso Machine
The red light for descaling won't go off after descaling
The button to push was the steam button and hold for 5 to 10 seconds until the light goes out.
Apr 22, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
Magic De Luxe Frother won't work!
means you do have the hot water button pushed and not just the steam function.
Follow this SAECO
Jun 03, 2008 | Saeco Magic De Luxe Espresso Machine
Won't make coffee
Could you please advise how I obtain a manual for a Saeco Magic deluxe
Apr 28, 2008 | Saeco Magic De Luxe Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Thanks
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
Coffee Makers & Espresso Machines Logo
118 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
