Question about Westinghouse Electric LCM-22W2 Monitor
I want to update the firmware or drivers for this monitor ''LCM 22w2'' (ca. 2006) but Westinghouse's website doesn't recognize the serial number and their tech support is closed on weekends. Is there another source? It keeps turning off since I updated Mac OSX to 10.5.8.
    Problem Solver:
  • 9 Answers
Don't need to update cuz it's not recommend to do that if it's not broken!!!!!turn on ur computer in mode safe wih network then try to recovering disk procedure(use the help menu or or the manual of ur pc) to ask to the system to restart the system few days or more before the updates cuz whan u allow automatically updates,it happens sometimes that the system becomes instable.when u will do this recovering procedure go and change this setting!!!!There is a condition for recover the system but i use windw and i don't know anything wit mac.DON'T update the firmware cuz u will have more problems if the system doesn't recognize components of ur computer and u will change them and u don't really need to do that!!!!just try it,be patient and stay calm, it happens to me and if i solved that, u can do that to.
Posted on Sep 13, 2009
Testimonial: "I think my monitor is just failing. I tried it on another computer and got the same problem. I have a mail open with Westinghouse for support..."
Trying to program my Westinghouse LCM-22w2 ComputerMonitor/TV with my AT&T U-Verse Remote Control. What's the code?
There is no tuner in the monitor, it only works as a TV with a tuner added. The remote would work with the tuner, not the monitor !
Dec 11, 2010 | Westinghouse LCM-22w2 Television
What and how much is a power supply board for the westington lcm-22w2 monitor. my tv went out i took it apart checked the circutry to me doesnt look like anythings rong. dont know what the caps are the...
Check here: <a href="http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LCM-22W2">http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LCM-22W2</a><br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: <a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a><span style="mso-tab-count: 1"> </span></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <span style="mso-spacerun: yes"> </span><a href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Aug 26, 2010 | Westinghouse Electric LCM-22W2 Monitor
My LCM-22w2 monitor will now rarely start up. It powers up white-screen and won't do anything. Occasionally it powers up OK and works fine.
wford451, You should open up the unit and inspect the "switch-mode-power-supply"/"CCFL inverter supply" printed circuit board for the common 2 problems that create symptoms like yours. Do some reading in my and other CCFL back-lit lcd monitor technicians fixya profiles. They are loaded with solutions to fix your unit. Your LCM 22W2 is no different than any other brand in it's basic design and operation!!! 12fixlouie
Mar 17, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Monitor Brightness
most user manuals for these moniters you can get on line (free downloads)
it will explain how to use the buttons on your monitor
Feb 02, 2010 | Westinghouse LCM-19v1 Monitor
10% of screen
I don't know if this will be a guaranteed fix for you or not, but you can try one of these.
1. Most Westinghouse monitors have an Auto button. Have you tried that?
2. If that didn't help, have you tried going through the monitors OSD (on screen display) via the menu buttons? You can manually control things through there.
As a side note, if it only happens when you play games, it may be that you have a driver issue. I recommend you upgrade to the latest drivers for your video card through either http://ati.amd.com or http://www.nvidia.com/
Hope this helps :)
Nov 29, 2009 | Westinghouse Electric LCM-22W2 Monitor
LCM-22w3 monitor suddenly changed colors. All
Try adjusting the monitor cable that goes from your monitor to the back of your computer.
Jul 10, 2009 | Westinghouse Electric LCM-22W2 Monitor
Westinghouse Electric LCM-22W2 Monitor Logo
747 people viewed this question
Top Westinghouse Electric Computers & Internet Experts
greg benton
vimal
vimal
Jerry Kramer
Jerry Kramer
Are you a Westinghouse Electric Computer and Internet Expert? Answer questions, earn points and help others
