Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
Need diagram for b&s 6 terminal ignition switch
    President:
  • 3,433 Answers
Bsppwebtools.com/data/manuals/1678_0esfw.pdf
or type in search bar for afdditional sites and info.
briggs and stratton electrical
Posted on Oct 31, 2009
How do you wire a solenoid on a 1955 thunderbird 6 v
Hello Jacqueline Iannuzzi,
The actual solenoid on that car is on the side of the fender ...
Large lugs are for the BATTERY & STARTER Cables.
The small terminals If one comes directly from the "S" terminal of your IGNITION SWITCH...
In a simpler time the "other" terminal was the "B" power to the ignition switch
(you should NOT have the 2 wire solenoid (I don't think)).
Hope this helps
http://www.rockauto.com/en/catalog/ford,1955,thunderbird,4.8l+292cid+v8,1435048,electrical,starter+solenoid,4188?a=Ad+Code+msn-Ford
More Information for ACDELCO U945
Dec 08, 2016 | Ford Thunderbird Cars & Trucks
Anyone have a wiring diagram or know how to hook this up ?
Black and red are pretty standard for negative & positive battery terminals.
There is likely a model number (pic isn't good enough to see the finer print) on the label but the larger numerals are probably serial numbers and without the model number, you may have a problem finding the exact installation info you want.
The link below has illustrations for a different model but manufacturers will generally stick with a wiring code to make installation and even production simpler:
http://www.mygen.com/users/dbruce/myz31/Jacobs%20Ultra%20Team%20Installation%20Instructions.pdf
That company does not have the web 'presence' they should have by now.
Apr 20, 2015 | Cars & Trucks
I have an 2002 Nissan altima and DA display on the radio is working but no sound
Hi candy Love , I love that name ! What Altima ? S ,SE or SL
AUDIO
Revision: May 2004 2002 Altima
AUDIO PFP:28111
System Description EKS002KQ
BASE AND MIDLINE SYSTEM
Refer to Owner's Manual for audio system operating instructions.
Power is supplied at all times
 through 15A fuse [No. 31, located in the fuse and fusible link box]
 to audio unit terminal 6.
With the ignition switch in the ACC or ON position, power is supplied
 through 10A fuse [No. 6, located in the fuse block (J/B)]
 to audio unit terminal 10.
Ground is supplied through the case of the audio unit.
Audio signals are supplied
 through audio unit terminals 1, 2, 3, 4, 13, 14, 15, and 16
 to terminals + and - of front door speaker LH and RH
 to terminals + and - of rear door speaker LH and RH
 to terminals + and - of tweeter LH and RH.
BOSE® SYSTEM
 to audio unit terminal 6, and
 to Bose speaker amp. terminal 1.
Ground is also supplied
 to speaker amp. terminal 17
 through body ground B117.
 to speaker amp. terminals 23, 24, 25, 26, 27, 28, 29, and 30.
Audio signals are amplified by the speaker amp.
The amplified audio signals are supplied
 through speaker amp. terminals 2, 3, 9, 10, 11, 12, 13, 14, 15, 16, 18, and 19
 to terminals + and - of subwoofer LH and RH.
SPEED DEPENDENT VOLUME CONTROL (MIDLINE SYSTEM AND BOSE SYSTEM)
If activated, the radio output volume will be automatically adjusted to compensate for increased driving noises
at higher driving speeds.
The radio receives a vehicle speed signal from the combination meter, and selects the output volume.
Feb 01, 2015 | 2002 Nissan Altima
Wire 253 holden boat motor starter alternator coil basic diagram
batter positive to one big terminal of the starter solenoid--large wire as in a car ( the other big terminal will have a wire from it going into the starter)
a wire from the start point of the ignition switch to the small terminal of the start solenoid .( This to energize the starter solenoid to start the engine.) a large wire ( 30 amp capacity ) from the positive terminal of the battery going to the BAT terminal of the alternator the plug in the back of the alternator will go to the battery light or ammeter.. wires from the start and run positions of the ignition switch to the coil. One to provide power when the starter is engaged and the other from the run position to provide power to keep the engine running
basic but it will work
Jan 25, 2015 | Holden Cars & Trucks
This question is for Strech.Hey bro you have give me a whole lot of information I know you are a very smart guy especially when it comes to bikes.So I don't know if you caught my question about the...
As far as the terminal board (terminal block, terminal plate) , I assume you mean something like this:
http://img.jpcycles.com/zoom/382-054_A.jpg
You may or may not be using all of the connections (they come in different standard lengths, and might have more connections than you need).
Now, I can't remember which wiring diagram I sent, so I'm starting over with this:
http://shovelhead.us/specs/wire/1976_FL_FLH.gif
The lower diagram is actually an continuation (to the right) of the upper diagram.
On the upper diagram, item #1 (to the right of the headlight, with little spots inside of it numbered 1 - 11) is the FRONT TERMINAL BOARD.
On the lower diagram, items # 17 - 20 comprise the REAR TERMINAL BOARD.
These show how many wires go to each terminal connection (example, terminal #3 in FRONT TERMINAL BOARD shows 5 wires connecting to that one terminal, #s 9 & 11 are not used).
Now your wire colors MIGHT not be stock.
In which case a multimeter would help you chase the wiring:
http://www.harborfreight.com/7-function-multimeter-98025.html
Also, do you have a Fat Bob tank center dash ignition switch?
http://i.ebayimg.com/00/s/MTA5MVgxMjI2/$(KGrHqZHJDME63ZMWiUbBO3tGwQzH!~~60_35.JPG
Or a key switch mounted somewhere else?
http://demonscy.ipower.com/i_pics/ignition_17-124_1.jpg
If the dash switch, this might help:
http://img231.imageshack.us/img231/931/dashswitchwiringdiagram.png
If a key switch, three wires would be:
1 - hot lead coming INTO switch
2 - lead going to ignition, brake light, instrumentation (for running without lights)
3 - lead going to lights (headlight, taillight) for ignition AND lights.
Hopefully, this will start you off.
Fire back with any questions
Feb 08, 2014 | Motorcycles
I need a wiring diagram for model # CRBIP 97171399
If you have only two wires and two terminals, it doesn't matter which one is which.
The thermostat is a switch. Your black and red wires would be the input and output to that switch. One is always hot, the other is hot only when the thermostat is calling for cooling, that is, when the switch is closed.
May 14, 2010 | Oasis Switch
Lakewood heater 7101 schematic
The power cord goes the switch terminal 1 and 3.
Terminal 2 must be the opposite of terminal 1, such that when switched on, 1 & 2 connects. Terminal 4 must be the opposite of terminal 3, such that 3 & 4 connects.
Under this setup, you may connect red to terminal 2
and black to terminal 4.
Be sure of the 1 & 2 pair, as well as the 3 & 4 pair.
then, connect the red and black wires.
Hope this will help you.
Jan 06, 2010 | Lakewood Oil-Filled Electric Radiator...
I have a 1993 murray lawn tractor 12.5hp Ignition Switch????
Take an ohm's and amp. meter and go to the ohm's setting and see which terminals are off and on. If you want to kill the engine put it on the off side. If you want to run anything put it on the start and run side of the switch. Hope this clears things up a bit. donnyb60.
Mar 24, 2009 | Garden
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
434 people viewed this question
Top Briggs & Stratton Hammering Experts
rlev_7
Level 1 Expert
Dan Webster
Dan Webster
John Trevino
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
