Question about Dryers
Hello I have a Kenmore clothes dryer (80 series) and it having a problem,the motor is working and the heat is coming in the dryer but the part where the clothes go to get dry is not turning ,what could be the problem ? and what can I do to fix this problem? I would be very grateful for your help ,I cannot afford to buy a new one at this time so I would like to fix this one with your help of course ,thank you so much.and have a great day.
  • Lisa Weezer
    Lisa Weezer Sep 16, 2009
    " Thanks. I opened the dryer and the belt was at the bottom. I can't tell were it goes on the drum. There is no wear marks. To guide me. Lisa "
Sounds as though the drive belt is broken or loose,check the pulley on the motor.Feel the belt if it's just loose you might be able to tighten it otherwise you will probably need to replace it.Regards Bigfoot57.
Posted on Sep 13, 2009
Testimonial: "Thank you so much for your information and explanation on how to fix my dryer ,I probably will be ok now thanks to your information,I will contact you"
    President:
  • 1,136 Answers
Hi, Sounds like the belt has broke. These instructions fit most models. If they do not apply to you dryer model, please get me you model # and I can give you exact instructions. UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Thanks
Testimonial: "Thanks. I opened the dryer and the belt was at the bottom. I can't tell were it goes on the drum. There is no wear marks. To guide me. Lisa"
  • Victor
    Victor Sep 18, 2009
    I am sorry this comment is delayed. If you have not yet got the belt lined up, the belt will line up toward the rear of the drum approximately 6" from the back.
    Vic
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
I HAVE A KENMORE 80 SERIES GAS DRYER. IT WORKS
Yes the moister sensor is at fault
Apr 29, 2010 | Dryers
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Kenmore 80 series dryer, no heat. blower works
Check to see if the glow bar is coming on first. If it isn't, it is probably the thermal fuse/ cutoff. It is a small white plastic piece on near the motor housing.
http://www.partselect.com/PartDetail.aspx?Inventory=345113&SourceCode=6
or
http://www.partselect.com/PartDetail.aspx?Inventory=344958&SourceCode=6
If it is coming on but not lighting the flame, then you probably need gas coils. They are the two cylinder shape black and white objects attached to the gas valve.
http://www.a-1catalog.com/gasvacokit2.html
Jan 15, 2010 | Kenmore 73952 Gas Dryer
Kenmore Series 80 gas dryer, clothes take 3 hours to dry
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Nov 04, 2009 | Kenmore Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Broken Kenmore 80 Series dryer
Sounds like you have a simple broken belt problem.  If you are sure the motor is working and the heating circuits are functioning, but the drum does not turn, the drum belt probably broke.  They are inexpensive to replace and are carried by almost any appliance repair store.
Oct 21, 2007 | Dryers
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Dryers Logo
185 people viewed this question
Top Dryers Experts
