Question about Kenmore Freezer 8.8 cu. ft. Chest Freezer with Hose Adapter
My chest freezer shut off (the outside light was
My kenmore chest freezer shut off (the outside light was off, and it was warming up inside) No breakers were tripped. When I slid the freezer away from the wall, to check the plugin, it started working. Any ideas why? It is only about 6months old.
  • 358 Answers
Try to plug somthing that you know it works ,in that outlet ,and if it doesn't work or goes on and off , the problem is in the outlet, but if works without trouble ,the problem could be in the freezer plug , the cord or the cord conections to the freezer.
Posted on Sep 13, 2009
  • christian nielsen Sep 13, 2009
  • ayesha fedrick Apr 20, 2013
    ayeshaF,,i woke up tis morning and my kenmore chest freezer 5.1 cu ft. was warming up and the meat inside was thrawing out, it been 1yr. and 6 mon. since i had my freezer what can be the problem?
Kenmore model 19502 chest freezer green light blinking
My Kenmore chest freezer just went dead today. It ruined my Ribeye steaks, my shrimps and other meats. I will not buy a Kenmore again.
Jan 12, 2013 | Kenmore 5.1 cu. ft. Chest Freezer - White
My kenmore chest freezer is the garage, the temperature outside is over 30 celsius, the side of the freezer where the motor is is very hot, and some other places on the front and other side is warm to the...
The hot sides is normal, this is how they expel the heat from inside the freezer, sometimes it may help to use a fan to help cool. Also make sure there is about 12" of room around all sides of the freezer .
Aug 22, 2017 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Chest freezer repair
I had the same problem with an upright and so I bought a piercing valve and charged the compressor with 134R and has been working great since.
Jul 05, 2009 | Freezers
The outside of the freezer feels warm to the touch
Hi ,
I have a stand up freezer and mine feels warm to the touch as well could be because of the ice forming inside i would say as long as it is working not to worry over it regards Jim
Feb 24, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Outside surfaces of freezer very hot to touch
it should be warm to the touch but not so hot you cant. and also depending on how long the freezer is running and how warm it is where the freezer is will effect how hot the outside is. the reason the outside of the freezer is hot is because thats how the freezer releses its heat from the refrigerant. the longer it runs or the harder it has to work the more heat it has to hive off. so unless the freezer is not cooling there is nothing to worry about.
Aug 07, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
357 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
