We have our dynex in an rv. we are on the road and when at a camp w/cable we are not able to receive all the channels...nothing above 12/13. why?
5 Suggested Answers
  • 579 Answers
SOURCE: cannot watch channels past 13
Your tuner settings must be set on broadcast instead of cable. Below channel 13, they use the same frequencies so it doesn't matter. Find the tuner settings page in the menus and change the cable/air setting.
Posted on Jan 06, 2008
bhiga
  • 119 Answers
SOURCE: Only channels 2-13 show on new Dynex 19" LCD TV
You'll need to find the Cable/Antenna setup and change it from Antenna to Cable. Sometimes the setting you want is called CATV.
Posted on Aug 13, 2008
rulds2008
  • 3866 Answers
SOURCE: Channel 100 and above on remote
100 + enter
that is the TV is programmed over 100 channels.
Posted on May 25, 2009
SOURCE: Have a 42 inch Legend
make sure cable is hooked to the right outside connection . had same problem two connections one for cable one for satellite.
Posted on Dec 06, 2011
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
Jul 24, 2015 | Winegard RV-5095 Sensar II RV TV Antenna...
My dynex 19" lcd tv doesn't work when i turn it on and try to set it up all i get is a distorted screen that you cant read i was told that it has to be reprogrammed is there software for a computer to fix...
When you turn it on press the set up/menu button. Make sure your cable is unplugged first. When in set up, go to channel setup and scan channels. Once the scan has started connect your cable back to the tv. Allow some time for the scan to complete. ***I learned this when I emailed a dynex technician. If it does not work after the above, email dynex http://www.dynexproducts.com/contact-us.html
Oct 08, 2014 | Dynex Televison & Video
Hi, I have a DYNEX 32in. 720p Flat-Screen TV. I am on Antenna & I can't get any channels below 16.1. I did Auto-scan. Anyone have any ideas? Thanks, AngelRock.
Do you have any other devices in your setup (cable box/modem, satellite, receiver, gaming consoles, etc)? What type of connection are you using (HDMI, composite/component)? Are you trying to obtain additional channels through a cable scan, or through basic antenna?
Mar 10, 2014 | Dynex Televison & Video
I'm going on a RV trip, which camping chair is recommended for me?
If you're going to a RV trip right to a campsite you can choose between two types of camping chairs, the basic camping chair and the comfortable camping chair.
Sep 04, 2012 | Bass Pro Shops Camping, Backpacking &...
3D tv issues with HD channels on Dish Network
check screen resolution of your lcd tv & receiver too
Aug 24, 2012 | Dynex DX-L42-10A 42 in. LCD TV
We are connected to cable, but don't get most of the channels, we are not using a box for cable. is there a way to het the channels/
Some of the older units in the cable band will not receive channels abover about channel 46---if this is the case nothing can be done.
Jul 16, 2012 | Panasonic PV-C1320 13 in. TV/VCR Combo
100 + enter
May 25, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
How do i run a channel scan? there is nothing in the manual
Found this in the most frequently asked questions at the Dynex customer support website on page 3. the website is:(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) You can also call the customer support telephone number at 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of you television and tell them you are having problems completing the autoscan of the television. I hope this information helps you with your problem. 1.How do I set up my channels or run an autochannel search? 2.Are you using a cable/satellite box, cable connected directly to the TV, or an antenna? 3.If you are using a cable or satellite box you must use the remote that came with that box to change channels. 4.Make sure you have the correct input selected to view channels via the cable or satellite box. For example, if the cable or satellite box is connected via component cables please press input and select Component 1 or Component 2 to view your channels. If you are using cable connected directly to the TV: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Cable. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Cable System, then press < or > to select your type of cable or satellite system. You can select STD, IRC, HRC, or AUTO. If you are not sure what type of system you have, select AUTO. 1.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all cable channels you receive. If you are using an antenna: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Air. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all analog and digital channels you receive.
Mar 16, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex (no database) since power outage
What you have to do it go to the TV Menu and go to channel. Then go to channel scan and do one of those. THe problem is that is just doesnt know where to look for channels, but a quick scan will fix that.
Oct 03, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
