Question about Sunpentown WC-140 Wine Cooler
I have a mini fridge that has completely stopped running. The outlet into which it was plugged works just fine. It seems such a waste to throw it out - any ideas are appreciated!
    President:
  • 1,865 Answers
There is no way to guess at the problem, you have to use a multimeter and troubleshoot the circuitry to find out which component had failed. Could be the thermostat
Posted on Oct 06, 2009
    President:
  • 1,653 Answers
These are fairly basic items and as such the following componets could casue the unit not to run.
The thermostat could be faulty and the most likely culprit and relatively cheap to replace.
The compressor motor may be faulty - fairly unlikely but if so it is fairly expensive to replace
and that is about it.
It is also worth checking that if your model has a samll colling fan at the rear that it is not blocked or frozen. This just draws air ac ross the colling vanes but will mean that the unit could overheat and blow the thermal fuse, again, if your unit is fitted with one.
You can get a new unit at
http://www.a14electronics.com/product-p/wc-140.htm
for $74.95
Posted on Sep 22, 2009
  • 986 Answers
I dont know what kind of mini fridge you have. Some have motor resets on the backside by the motor/comdencer. Hope this helps
Posted on Sep 13, 2009
I have a Galanz mini fridge model number #GL27S5- the fridge seems to run ok during the day. It shuts off at night everything in there is warm. How can I fix this?
Not trying to be smart but it sounds like the outlet it is plugged into might be controlled by the light switch. Switch off, fridge off. Just a thought.
Apr 21, 2016 | Refrigerators
Galaxy mini fridge stopped working
The thermostat, which is also an ON_OFF switch has failed (@ 99% probability).
No, the little fridge doesn't have a pressure switch to turn the compressor off when freon is low. And no, auto freon is the wrong kind and it wont work in the little fridge. The freon that your little fridge uses is the stuff that all the fuss has been about (with the ozone layer), so it is not sold to appliance owners but only to licensed techs.
If this is helpful I hope you'll take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Koolatron Mini Fridge Compact Refrigerator
Our refrigerator keeps tripping the gfci outlet it is plugged into in our garage. After several days we tried it again, and it worked for a while before tripping it again. We cleaned out the bottom...
first thing to do if it is continually tripping is to replace the gfci. they do go bad over time. Shut the breaker off to it. remove and note which wires go to which screw. if it gets wired wrong because going by memory. tis not fun trying to figure it out.
Best of luck
hope this helps and solves it. It should, if not call a tech for the fridge. or post model and make and we can go from there.
Jan 07, 2018 | Roper RT21AKXKQ Top Freezer Refrigerator
Hi, I have a Kenmore top freezer refrigerator model number 363.79567990. The freezer stopped working and I found out that I had to press the "Reset" button on the outlet while it was unplugged...
It sounds like you've plugged your fridge into a GFI (ground fault interrupter) outlet.
The National Electrical Code (NEC) article 210.8 A (6) says in dwelling units, only those outlets in a kitchen (I'm assuming your fridge is in the kitchen - right?) "where the receptacles are installed to serve the countertop surfaces" must be provide ground fault protection aka "GFI outlet". Unless your town, city, county or state has laws that supersede the NEC, you should have the outlet changed to a standard, grounded outlet to prevent the nuisance tripping you are experiencing when the cooling compressor is trying to start. A refrigerator is not a counter surface appliance, and therefore does not require GFI protection.
The other outlets are fed from this outlet, so when you connect the fridge to another outlet on the circuit, the same GFI plug trips again. When you replace the GFI plug with a "regular one, the GFI plug should be installed in another outlet to provide the GFI protection needed in the kitchen - as described in the NEC above. If you are not familiar with how to do this, please, call a licensed electrician to do this very important job for you. Be safe & be smart.
I hope this helps!
Nov 01, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge won't start up.
have you tried testing the plug. Has the fuse blown in it? try changing the plug to see, then if this doesn't work try a different power outlet.
Sep 07, 2009 | Haier HNSB02 Refrigerator With Ice Box
The fridge has completely stopped. There seems to be no power. Is this maybe a fuse thing?
hope your food isn t spoiled ,first of all grab a lamp and plug it into the same socket and if it doesn t light check your breaker second if you know which outlet does work get an extension cord and run that over to fridge and plug it in and see what happens could also be a breaker be careful electricity if the fridge starts your doin good
if not bad fridge sorrry
Aug 10, 2009 | Fisher and Paykel Refrigerators
Refrigerator keeps throwing receptacle switch plate
I'm assuming this is on a GFCI outlet? May be a problem with the outlet rather than the Fridge. I had an outlet that would do the same thing when it encountered loads. I replaced it and everything was fine.
May 23, 2009 | Kenmore Refrigerators
Refridge stopped working after a power surge
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Apr 03, 2009 | Refrigerators
Fridge has been working great then this morning no power.
try plugging your refrig into a different outlet, or plug something else into the outlet the refrig is plugged into to verify power to the outlet.
Jan 30, 2009 | Samsung RS2630SH Side by Side Refrigerator
Sunpentown WC-140 Wine Cooler Logo
185 people viewed this question
Top Sunpentown Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Sunpentown Refrigerator Expert? Answer questions, earn points and help others
