Question about Toshiba Satellite A100-S8111TD Notebook
Hibernating I have a Toshiba laptop. If it is on for more than a few moments it will go into hibernation. I have changed all settings in the power options but no help. It will do this even if I remove the battery pack and just plug it in to the wall. If anyone can help it would be appreciated. I am running XP so I know it is not vista causing the problem. I have run several different antivirus, antispyware, antimalware, etc programs but it comes up clean and no help there either.
  • 1 more comment
  • mystfyu2 Sep 13, 2009
    All hibernation modes are stopped. I will get a nice nasty blue screen when I reboot......
    SWUMx56.SYS
    Page_fault_in_nonpage_area
    stop:0x00000050
    (oxFF9D8050, 0x00000000, 0xAA445743, 0x00000000)
    I have tried to update everything through microsoft and internet explorer but so far nothing has worked.
    SWUMx56.SYS
    stop:0x00000050
  • Jim LeVan
    Jim LeVan May 11, 2010
    have you disabled hibernation all together in the power options?
    Sergeant:
  • 166 Answers
In power option properties, in hibernate tab, there will be an option checked (enable hibernation) just uncheck that option.
Posted on Sep 13, 2009
Power light flashing
Is it in hibernation, stand by mode? Shut down computer completely. Go to power settings change hibernation setting to off or uncheck.
Nov 10, 2012 | Toshiba A605-P200 TOSHIBA PORTEG Laptops ...
Left laptop on, when I cam back went in hibernation, I cannot wake it up
simple fix okay turn it off then turn it back on then when it is on go to control panel and power settings and change the hibernation options
Apr 11, 2011 | Computers & Internet
How to calibrate battery laptop toshiba satellite m45-s359
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Dec 13, 2010 | Toshiba Satellite M45-S359 Notebook
My Toshiba Satellite L305-S5877 will sometimes go into a "sleep" type mode randomly and the screen goes almost completely blank. I can just see what is on the screen very faintly. I checked and...
You have to disable the hibernation mode. Sounds like this is the problem. Go to Start - Control Panel - Performance and Maintenance - Power Options - click on Hibernate tab and uncheck where it says Enable Hibernation. This should fix the problem. Cheers
Oct 02, 2009 | Toshiba Satellite L305-S5877 Notebook
Put my toshiba laptop into sleep mode closed the lid, reopened it within seconds, and now the laptop will not come back on
Reboot the laptop, go to control panel > power options > go through the settings, especially what does the computer do when lid is closed and change the setting to "do nothing", turn off hibernation if it is on. Change other settings to now allow the computer to go to sleep, just let it run until you decide to turn it all the way off. Sleep mode and Hibernation cause more problems than do good.
Sep 17, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba A135 random shut downs
chect the operating system maybe some files or configuration change.. try to re install the operating system,, save first you data or make back up.. in another drive.
Jul 06, 2009 | Toshiba Satellite A135 Notebook
ToshibaHotkey
go to control panel,power options,
change your power settings
stop Hibernation,
" choose what to do when I hit the power button" etc....
Hibernation causes problems with startups
Don't use hibernation, use standby,sleep
or turn it off completly
should cure the problem
Regards
Richard.
Apr 19, 2009 | Toshiba Satellite 1415-S173 Notebook
I do not know how to get my computer off of hibernation mode.
hi
to remove the hibernation mode goto screen saver setting then you will see the power,click n power box and you will find hibernate option,click that box and you will see hibernate enable box with check.un-check that box and restart your pc
Dec 13, 2008 | Toshiba Satellite A60-S1561 Notebook
How to turn on toshiba satellite M300 laptop from hibernating mode
hi shirleygty, is that automatic hibernation (the computer hibernates by itself) or manual hibernation (by pressing the hibernate button)? If either applies to your case you might need to update the BIOS information for your computer to fix the power management issues on it. You can get it here. Just run the file, click install & choose Install From Windows. Make sure you don't have any BIOS password or any external devices connected to the computer. When the update completed successfully, your computer will automatically restart, then try hibernating this time (manual or automatic). I do recommend setting the hibernation to 1min. at the control panel > power options > change when to turn off the display. When it hibernates, pressing any keys or the power button should wake up the computer.
Hope this helps.
Oct 05, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
