Question about Nikon COOLPIX S6 Digital Camera
I have a coolpix S6 and when I turn the camera on the screen is black with the icons showing. When you switch modes to see what pictures look like that screen works fine. What could my problem be. Thanks for your help
  • 3 Answers
Just hit it real hard in the front until you get tired or until it shows it worked for me
Posted on Oct 27, 2009
  • Brandon
    Brandon Mar 12, 2011
    Been on black screen for over 4 years.... I turned it on held it in one hand and hit it with my shoe a few times. it would shut down and i had to take battery out. but i did it three times and bam it works now.. cant believe it. its back.
When i take a picture, my picture comes out black the camera turns on fine, batteries are charged and everything. but the screen is black. it acts as if it was going to take a picture but the screen does...
Your camera may be manifesting shutter not opening problem. It needs to get to a camera service/repair shop.
However, it's good you physically check whether the lens isn't blocked or covered with anything
Oct 12, 2017 | Nikon COOLPIX S6 Digital Camera
My coolpics s6 has a black screen when in picture taking mode - as if the lens is not open. icons display, and show pictures mode works ok.
Switch on the screen in setup. The screen is now in 'power saving' mode and does not lit up while taking pictures.
Nov 25, 2009 | Nikon COOLPIX S6 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Nikon s6 coolpix
I would check with Nikon and see if it's covered under warranty still. There could be something going on with the CCD unit
Jun 14, 2008 | Nikon COOLPIX S6 Digital Camera
Problems taking pictures
Six months - Yes warranty.
Yes vendor still liable
Coolpix s6
You should be able to turn the screen on while taking pictures so that you can see what is going on a little easier. Here is a link to the manual where you can find where in the menu to turn the LCD on. I tried to get the manual for myself so that I could give you page numbers and such, but it requires that i give a serial number number off the camera, so be sure to have your camera handy when you do this.
Aug 27, 2007 | Nikon COOLPIX S6 Digital Camera
About taking picture
u need to set your flash mode on auto mode u can by pressing flash button or u can press menu & selet reset and ok it
Jul 14, 2007 | Nikon COOLPIX S6 Digital Camera
Camera LCD is black
If you want to follow my way to try fixing it yourself, keep reading and do it at your own risk. You paid several hundread dollars for the camera and I just paid $20 for it. Therefore, I tried everything I can to make it work, even if I had to open the camera body to play with the inside. Fortunately, it was not neccessary to take it apart.
Once again, AT YOUR OWN RISK to follow my way to get back your real time image screen.
Read the following steps once and make sure you understand before action.
(1) Load your camera with a freashly recharged battery.
(2) Switch on to see if it's working and still without the real time screen.
(3) Switch it off, and hold it tight in you palm with the LCD facing inward.
(4) Now, with you palm up, you should be able to see the model name 'CoolPix S6' under the lens and the flash.
(5) While holding the camera and aiming at the 'CoolPix S6', raise your other hand with the fist next to your ear.
(6) Match the aim as describe in(4) to the aim of your elbow 's protruded part and make pratice moves. Yes, you'are going to smack it
to your elbow.
(7) When you are ready, try first not to hit your elbow too hard once.
(8) Switch the camera on to check. If you have the 'Screen' now, congratulation! If not, repeat (4) to (8) but with a stronger impact
Force. You might have to try more times until your elbow could not take the sore.
I got mine fixed by performing the above steps just once, but I started at a medium impact force. Before this fix, I tried to whack it on both sides, the top and the bottom to my knee cap.
Why I chose knee cap and elbow? They hurt if you strike too hard. The target is to apply enough impact force to shake but not break the parts inside the camera.
Good Luck!!
Apr 16, 2007 | Nikon COOLPIX S6 Digital Camera
Nikon S6- LCD screen black
I have The same problem with my S6, and was wondering if you found a solution? Ive done everything but contact Nikon or a camera shop.
Nikon COOLPIX S6 Digital Camera Logo
328 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
