Question about Eddie Bauer Deluxe High Back Booster 22-862
22800-CHL CAR SEAT INSTRUCTIONS FOR THE SHOULDER STRAPLS i NEED INSTRUCTIONS ON HOW TO SET UP THIS CXAR SEAT PL;EASE....MY KID HAS GROWN AND THE STRAPS ARE SHORT AND WE HAVE NOIT BEEN ABLE TO FIGUFRE IT OUT.. THANKS r
  • 74 Answers
In the front there is strap that is hanging with a button push the button and pull on the straps that go over the child to loosen. bottom strap anging out the front tightens the strap as needed
Posted on Sep 14, 2009
Extend britax hi-liner
maybe shes just grown out of it you should take it back and change it (depending on how long you have it) or just buy a better one that fits her right !
Aug 09, 2012 | Britax Hi-Liner - Prague Booster Car Seat
Tip
How to Install a Child Seat
FOR LARGER KIDS: If the child is over 35lbs, use the belt and shoulder harness as you would an adult and simply extend the belt over the seat. You do not need to install any of the built in straps.
SMALLER CHILDREN (UNDER 35 lbs):
1) If your child is under 35lbs get the locking clip that came with the seat if you have a seat with a shoulder harness attached. Otherwise, it isn't necessary. Pull the shoulder harness down to the base of the waste strap and then use the locking clip to bind it into place.
2) For a smaller child you will need to install the built in straps like so.
3. Set the seat in place running the waist strap through the back of the seat and clipping it on the other side.
on May 06, 2010 | Baby Gear
How to remove a back seat from 02 toyota avensis
Hi, peel the cover from around the seat frame so that the shoulder strap hold the cover on to the seat.
Extend the set belts to their maximum length and recline the seat as far as possible.
Looking at the seat from the front, put your hand in the gap between the reat of the seat (bit that reclines) and the fromt of the fixed base (by the red dome and the instructions).
On the bit of the seat that reclines there is a 'door' that opens to reveal a metal clasp that the ends of the shoulder straps fix to at the top and the ****** belt at the bottom.
Unhook the looks from the shoulder straps from the metal clasp.
Pull the shoulder straps through the back of the seat upright. You can now pull them through the cover which is free for you to wash.
Thank you.
Jun 06, 2012 | Cars & Trucks
Instructions for graco junior mini car seat
http://www.graco.fr/pdf/8H98%20MODEL%20GB%20FR%20NL.pdf
I found the instructions on the french graco site. Hope this helps anyone else looking through for this old car seat.
Apr 09, 2012 | Graco Baby Gear
I have a turn a tot car seat and the straps that hold her into the seat are to long and i can't work out how to shorten them and i can't find instructions anywhere
I guess you have pulled the harness adjuster strap tight (between the legs on the front edge of the seat) and are still left with slack shoulder harness straps. It may mean you need to remove the seat and check the harness straps are going thru the shoulder slots in the seat, then they need to go up and over the the metal shoulder rod before going down to connect onto the metal spreader plate
Dec 13, 2009 | Baby Gear
Removing seat cover maxi cosi priorifix
To be able to remove the seat cover from your seat you have to 'unhook' the seat belts at the back of the seat:
First extend the seat belt to the maximum length.
Then put the seat at the maximum recline.
At the back of the seat-'shell' you will then see a metal hook that hold the shoulder straps: unhook and pull forward.
Reassembly is just the reverse.
A few more tips when removing the cover from a PrioriFix: take care not to damage the white extruded foam when pulling the belts forward and when taking off the cover. When the foam is not protected by the padding it may easily snap.
The seat padding is cold wash only and no spin-dry, otherwise the seams may loosen.
Please don't hesitate to use the contact form at http://www.babycare.nl if you need any further assistance.
With kind regards,
Babycare.nl Sales Desk,
Erwin de Raad
Jun 21, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Moving of seat belt to a higher level
The straps must be undone from a claw on the underside of the car seat so you have to remove the whole thing from the car. The claw is designed to keep the straps in place and this it does very well but its position on the undercarraige leaves no room for your hands and makes it near impossible to manage.
Jun 13, 2009 | Britax Eclipse Si - Paris Convertible Car...
Lost my Instructions for a Britax Asis Car seat
First attach the long belts to the bottom of the chair. Then feed them through the seat cover and replace the cover. Feed the belts through the back of the chair (through the required shoulder height) and attach to the metal harness at the back of the chair. The folded over edge goes on first, so make sure you put the right belt on the right side! Finally, feed the padded shoulder straps through the same hole as the long belts at the to of the chair and that's it!
Any more problems, drop me a line
Apr 11, 2009 | Baby Gear
Car seat missing manual!!!please help!
Manual is available at the manufacturer's website
http://www.coscojuvenile.com/instructions/
Aug 17, 2007 | Cosco Alpha Omega Convertible 22-150
Eddie Bauer Deluxe High Back Booster 22-862 Logo
1,267 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
