Question about Frigidaire FWS833A Top Load Washer
The plastic drum just keeps spinning freely during the wash cycle
    Problem Solver:
  • 10 Answers
Yes! to let you know that this is NORMAL when the washer agitates, due to the "Westinghouse" designed transmission, which in turn is called the "Franklin" design.When the agitator returns back stroke the washtub "indexes" before the agitator strokes forward. Thus moving the load around through the water while being moved back and forth.
Plus! to let you know that since the washer does NOT have "brakes" to stop the washbasket and hold the basket this design allowes the "indexing". This is one of the main reasons your washer has a safety lid interlocking device on it to lock the lid when it spins, because the washer has no brakes to stop the machine if the lid is opened during a spin cycle.
Posted on Sep 13, 2009
During wash cycle of my Maytag Legacy SAV515DEWW, tub moves freely and after spin cycle, tub keeps spinning for a while.
Maytag has a drum brake located on the bottom of yor machine. You need to remove the brake and clean it up or perhaps replace the device.
Google Maytag washer drum brake for several "how to"sites
Nov 30, 2014 | Maytag Washing Machines
When it gets to the spin cycle it amps out and pops the breaker
Sounds like u need to change belt. Also check to see if the drum spins freely. If resistance on drum see why.
Dec 28, 2012 | Speed Queen AWS17NW Top Load Washer
What will cause the drum not to spin during cycle? It spins freely by hand. Belt is in tact and motor shaft turns freely manually?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 15, 2010 | Frigidaire FCCW3000F Front Load Washer
Whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
May 15, 2010 | Washing Machines
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Frigidaire FWS833A Top Load Washer Logo
116 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
