Question about Kenmore Refrigerators
Kenmore refrigerator-- freezer is working fine. Refrigerator is freezing food. I changed the temp dials to send coldest air to freezer. Food is still freezing any suggestions.
  • Anonymous Mar 29, 2014
    freezer not freezing food
  • Kenmore Master
  • 4,654 Answers
I need the model number that Sears put on the fresh food section door to confirm. Until I know which model you have I need to assume that it has an electrically controlled damper between the freezer and 2 temperature controls. I also have to assume that they both are connected by their wiring to a Adaptive Defrost Control. If one of the three things listed is not working then that part will need replaced. Now there are cases when the damper door becomes stuck and you would need to unplug the power and open the rear panel in the back of freezer to see if frost or ice has the damper stuck wide open. Sears numbers look like this for example 231.564897 bottom of fresh food door behind door seal and near floor kick plate, Let me know what you find and I will be happy to help you, Thanks, Sea Breeze
Posted on Sep 13, 2009
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Is the dial to adjust temp coldest set at low numbers or high number?
The dial inside the fresh food compartment, the bottom compartment
set to middle or above (higher numbers mean colder). Usually 5 to 9 if it has numbers.
Freezer knob in the middle if it has one. (If you set a freezer knob to "colder" it cuts
off the cold air to the lower compartment). Hope this helps
Jun 29, 2011 | Kenmore Top Freezer Refrigerator
All food on top shelf of refrigeratr is freezing
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 17, 2009 | Refrigerators
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
The freezer temperature is too high. is it controlled somehow? the fresh food compartment is a bit warm too - though the setting is on coldest.
I've made a mistake before with thinking that I was setting the adjustment correctly on a refrigerator before, sometimes those dials are hard to read if there is a graphic scale, or symbols etc. Instead of numbers with the highest number being the coldest setting. Anyway make sure the temp setting is set correctly, these are found in the refrigerator side.(yes even for the freezer, so it does'nt freeze up) I adjust mine all of the time, things only need to be so cold right.(helps my elect bill) Make sure those special compartments have clear air passages to them. best regards.
Jun 08, 2009 | Haier HRF10 Top Freezer Refrigerator
Vegtables freezing in refrigerator drawer
This could be due to frozen air passages...defrost the unit, food packed too close to the passages, possibly low on gas.  First, clean out your condenser radiator at the bottom of the unit...rear.  It is probably blocked.
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
183 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
