Question about Amana NED5400TQ Electric Dryer
Dryer was working the just stopped and won't start back
Our dryer had been working all morning and then we put another load in and it started, turned once then stopped and hasn't started back since. what can we do?
    Problem Solver:
  • 15 Answers
Check your main breaker box first, see if it tripped, if the breaker looks okay then turn off the breaker for the dryer and reset the breaker switch, if this still doesn't work then a fuse has popped on the circuit board.
Posted on Sep 13, 2009
Put a load of laudry in the dryer that was still holding water. Dryer stopped running and there was water sitting in the dryer. Now the dryer won't run
Hello, Welcome to FixYa.
There are a couple of scenarios which may prevent the dryer from starting with Bosch.
To save time and back and forth dialog, I`ll mention the most likely based on your description, "put a load of laundry in the dryer that was still holding water. Dryer stopped running and there was water sitting in the dryer. Now the dryer won't run"...and what to do about it.
**Unplug the dryer before attempting any repair tips suggested here please...safety first**
There is an auto shut off or emergency kill switch next to the motor which will prevent it to start in the event it was tripped for whatever reason... likely from the excessive weight of the load you put in.
It will look like this image below and all you need to do is push it to the right ( from the back )...
i.e.
If you`ve already taken the back of the dryer off to gain access you should have no problem. If you never have, it`ll take some time.
Either Scenario I alluded to ( the other would be resetting the hi-limit cut out, you can see through the back vent opening when the vent is removed and then by pushing the red button in...shown below ) will require the removal of that panel so let me know if you require further assistance to do this.
i.e.
Keep me posted how you make out or if anything is not clear.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Oct 29, 2012 | Bosch Nexxt 500 Dryer
Did a load of laundry this morning...took that load out of the dryer, put in another load and when i went to start it.. the dryer would not turn back on..check the wires, dryer vents...switched the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Whirlpool Dryers
Dryer won't turn over/start. When push start switch makes noise but won't turn. If hold door closed switch and turn manually while pushing start button it would work for awhile, but that has...
heatman101
Sep 05, 2011 | Amana Dryers
My frigidaire gallery electric dryer won't turn on. In the past it has been a bit on the noisy sound with a squeaky sound coming from the back. The last time I went to put a load in the dryer the...
heatman101
Aug 27, 2011 | Frigidaire Dryers
I put too many wet items in dryer. I think.. it stopped and won't turn on.. it would buzz when trying to start it, but now won't do that.
heatman101
Jul 23, 2011 | Kenmore Dryers
Dryer appears to 'overheat'...starts a load but stops before finishing then won't start again for hours...
Test air flow. Remove the exhaust hose at the rear of the dryer, run the dryer and form an opinion on the volume of air flow, hook the hose back up, turn on dryer again and verify that the same volume of air exits the building. Usually a build up is the cause of your complaint.
May 13, 2011 | Kenmore Dryers
My GE DBSR453EB1WW electric dryer doesn't turn on. It worked fine yesterday morning for one load and when I put in my second load, it wouldn't start. It is plugged into the outlet and the breaker is fine....
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Nov 15, 2010 | GE DBSR453EBWW Electric Dryer
I have a 10 yr old Maytag dryer that has been acting up lately and wonder if anyone can help. I can use the dryer and dry a load of clothes and it work fine. Go to put the next load in the dryer and it...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 22, 2010 | Maytag Dryers
Amana NED5400TQ Electric Dryer Logo
155 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
