Question about Dryers
Maytag dryer squeeks when I first turn it on. Started about a couple of weeks ago. Squeek would go away after a few minutes, however now it is continuous.
    President:
  • 1,136 Answers
Hi, The most popular squeeling issue in the Maytag dryer is caused from the idler pulley. The idler pulley keeps tension on the belt. The next possible problem could be the 2 rear drum rollers. These rollers are fastened to the rear bulk head and they support the drum. The third possibility is the motor bearing. Usually, when the motor starts to squeel, the motor will shut off suring the cycle and will not restart until the motor cools down.
I would advise you to change the idler pulley as well as the rear support rollers. The cost for these parts are very costly and a little preventive maintainance goes a long way.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Sep 13, 2009
Dryer squeaks when turned on, recently is getting louder and louder as drum is turning. Is it worth getting fixed, it's six years old
The squeek is probably the front 'bearing' which is generally made of felt.
Pop the top, pull off the front, remove the drum. Clean the felt or replace it.
A better alternative is to turn up the radio so you cant hear the squeek.
If you do go to this trouble, you may want to replace the belt while you have it apart.
Personally, id let it squeek. It may be annoying but on the ohter hand, you know when it is operating and when it is finished now.
Oct 21, 2009 | Dryers
My drier makes a squeeking noise and overheats after about 10 minutes. What is wrong and how do I fix this?
You have a partial or full clog in the exhaust. Pull the machine from the wall and disconnect the hose ... start cleaning with a shop vac ... go both ways. If your hose is plastic, replace it with flexible metal. Dont forget to clean the outside vent.
The squeek is probably the front 'bearing' which is usually felt and rides on a ring around the door. Best fix is replace it, next best is clean it ... the fix i use it I turn the radio up until the noise goes away.
Oct 08, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Neptune clothes dryer Model# MDE4000AYW Noisey squeeking sound. However, after a few minutes when it heats up, the sound goes away.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
trxcvhj
Jul 05, 2009 | Maytag Neptune MDE6700A Electric Dryer
I have a Maytag Legacy Dryer SDE305DAYW that is squeeking. How do I change the belt?
the belt is not causing the squeek. either the tub rollers, or the idler pully is squeeking. you must remove the front panels and drum to inspect these parts. usually when a roller or idler pully is squeeking, you need to replace them. if they arnt to worn, you can clean the shaft and grease them to stop the squeek, but i dont recomend that, as it will just be a temporary fix and will start squeeking again. this isnt a easy repair if you've never done it. let me know if you have any further questions. Shane
Jun 19, 2009 | Dryers
Brakes squeek
did you put on any no squeek on the back of the pads if you did not you may have to take them back off and pick up a small package at a auto store.
Feb 26, 2009 | 2003 Chevrolet Cavalier
LDE412 MODEL MAYTAG DRYER, LOUD SQUEEK
Are you sure that is the model number? I can`t find that model number anywhere. Please check the tag on the machine. This tag should also have the serial number on it.
Nov 10, 2008 | Dryers
Maytag dryer model # LDE5005ADE has a squeaky noise when starting up to dry clothes
thanks for the question. If your dryer squeeks just a short squeek just as you start it thats not a big problem If the noise is there all the way through the cycle it could be the drum rollers locatedat back wall of dryer ,the drum rides on 2 of these they could be worn if its a short sqeek could be a slightly worn belt . thanks for the question The appliance doc
Sep 10, 2008 | Maytag Dryers
MAH3000AWW
Replace both the main control board and the wax motor. This sounds like a computer chip malfunction
As far as the squeak, make sure it is not the bearing located at the back of the tub under the large pulley.
Jan 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Squeeking in lower dryer
remove the rear panel. unplug dryer before doing anything
Oct 24, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
76 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
