Question about Canon PIXMA MP150 All-In-One InkJet Printer
Scanner error says i have a scanner error and to close scanner and consult manual...i dont know where manual is..
    President:
  • 1,126 Answers
Cartridge error 50C
Hi there Error 50c
This not same dell as yours but who knows it may well work for you.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 04, 2010 | Lexmark X5150 All-In-One InkJet Printer
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Message states, "Scanner error. consult manual and call tech assistance if necessary" on Photo RX 500. Printer will not print from computer
The printer is likely to have an internal error. The only thing you can do is turn it off & check for anything inside (just by looking). If the same error, then the printer needs to be serviced.
Oct 20, 2009 | Epson Office Equipment & Supplies
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Cartridge Error
Aug 13, 2009 | Dell A940 All-In-One InkJet Printer
Cartridge Error, Error 50C
Hi there Error 50c
Dell gets this lots so have a try.
color cartridge.
Mar 02, 2009 | Dell A940 All-In-One InkJet Printer
CanoScan LiDE 50 error code: 2,7,0
Has your scanner been working before?
If so, has anything changed since then such as new printers or other devices added to the computer, or upgraded to a new OS?
Which OS are you using?
When exactly does the error occur?
Does ScanGear open?
Are you able to preview?
Try connecting the USB cable to another port on the computer (directly to the computer...not through a HUB or any other device). Bypassing a hub, which would have to be a powered HUB, or other devices would rule out any issues with those devices.
Ultimately trying the scanner on another computer would rule out issues with the scanner as well.
May 09, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Error 201
Which scanner is this? Error (201) usually indicates some sort of power issue...such as the scanner is not getting enough power. If this is a USB powered scanner you may try connecting to different USB ports on the computer.
Mar 28, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Error 2200
Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
Power off the AIO and remove the power supply from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO.
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
IF THE ERROR MESSAGE DID NOT COME BACK....
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Maggie B
Feb 12, 2008 | Lexmark P4350 All-In-One InkJet Printer
My Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Cartridge Error
Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x6100
Cartridge Error 50C
  3. Uninstall and then reinstall your cartridges.If this does not resolve the issue then try the next steps.
Good luck and dont forget to rate me!!!
Dec 19, 2007 | Lexmark X6100 Flatbed Scanner
Canon PIXMA MP150 All-In-One InkJet Printer Logo
60 people viewed this question
old marine
old marine
