Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Have a samsung projection hd tv monitor 1080i auto perfect focus tv....that's what it says on the tv front. my grandson came by and he's 1 and pushed the video/tv button, now i tried to turn my tv on and i have no picture. i pushed the tv/video button, still nothing. usually, the on/off button on the tv will go green when it's turning on and makes a little sound/tune - which lets me know it's coming on.....it's not doing that, or anything else. i have no way to tell if he's changed it from the proper channel so i can view my satellite - what is wrong w/my tv?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
I need help in identifying whether or not my magnovox is 720p or 1020p. The ID # is 37mf437b/37 and the serial # is bz3a0722610855
Google the model number--owner's manuals are available on the internet for free.
This model (37MF437B/37) IS A 1080P SET.
If you need more information or advice let me know--I am here to help people.
If this helped you, rate this solution as I do this here for free.
SD TECH
Nov 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
The screen looks out of focus and the top and botton bend inward.
Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Sep 26, 2009 | Sony KP-53S65 53" Rear Projection...
Samsung hdtv1080i saying check factory data self focus nt wkg
Hope this link helps mate,
http://www.howtomendit.com/answers.php?id=79076
Darren
Dec 31, 2008 | Samsung HCN436W 43" Rear Projection...
What do I need to get for viewing HDTV
The TV you have will only process an HD via the component video connections. Your cable box needs to have component outputs and you will need to buy a component video cable to connect from the cable box component video outputs to the TV's component video inputs (should be 2 sets, #1 for up to 720p and #2 for up to 1080i...
Oct 28, 2008 | Samsung PCL5415R TV
Samsung 42" rear projection HD tv issue
1 they are either rebuilt or a defective returned to stock accidentaly
2 yes securly attaching it helps the heatsinks keep even cooler. no you don't need heatsink grease.
3 if the tolernace is very far out of wack then it woun't take long befor they blow. once you have instaled the new board turn on the set enter mute,1,8,3 then perfect focus on the remote let it do it's thing then shut off the tv and resart the tv and press perfect focus again.
Mar 05, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung 1080i
ic chips are no good if u can open it up get fan on it blow dust out for super bowl keep it cold
Feb 03, 2008 | Televison & Video
Prefect focus control
On the remote you have a door. Open it and you'll find the button focus on the right side the second from up to down. If not is in the menu, go in setup, convergence, auto, ok.
Jan 04, 2008 | Samsung HCN4226W 42" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Wierd problem
HD projection televisions have seperate convergence alignment for 480i-1080i thus your problem when you use your XBOX360. The "No sensor data" that shows up is due to the fact that the sensors need to be initilized after doing the convergence in 1080i mode. You will probably need a technician to do the alignment because if it is out that much then a template needs to be used to get it corrected. For now you can put your XBOX in a lower display mode until repairs are done.
Jan 30, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
720 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
