Question about Black & Decker Black Decker 16" Hedge Trimmer
Purchased hedge trimmer in 2004 - worked great until this week. Just stopped - however if I shook the machine it would run. Now just gave out entireky. Please advise??? I Boretti
Purchased a new hedge trimmer - Thank you for your help
Posted on Sep 14, 2009
Electric hedge trimmer want run why?
electric hedge trimmers have 2 switches to press before it runs
one is the trigger that you pull and the other is in the handle that you hold in your left hand
both have to be on before it starts
it is a safety feature to stop operators cutting off their fingers
Jun 09, 2016 | Little Wonder 2230S 30 Single Side Hedge...
Mitox 28lhr long hedge trimmer does not start properly. It takes at least 50 pulls of the start cord before it starts. I've changed the spark plug but to no avail. Any advice on how to help it start
  1. Switch machine to On position.
  2. Switch choke to full.
  3. Pump the primer bulb 5 or 6 times to prime the carb.
  4. Lock the throttle on with the throttle switch.
  5. Pull over until engine fires. (it may only be a quick pop)
  6. Switch to half choke.
  7. Pull over until engine starts and runs.
    Also check the air filter is clean and the fuel filter is good.
    I've added a link to the manual incase you didn't have it. Page 30.
    http://www.mowerspareparts.co.uk/v/Mitox%20manuals/271MT281MT.pdf
Apr 09, 2016 | Garden
I have a petrol hedge trimmer TRY26PHTA. The engine will start fine but the blades will not move
If the engine starts 'fine" then it has not seized.
Many, if not most, hedge trimmers are , for safety, equipped with a "CENTRIFUGAL CLUTCH" between the engine and the blade to prevent blade operation unless the engine is at full RPM.
IF your machine is so equipped, it's possible that the clutch is worn and slipping so badly that the blade can't move.
Jun 11, 2014 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Why does a Stihl hedge trimmer stop after 20minutes
I'm not familiar with your particular machine, BUT...
That symptom can be caused by lack of lubrication leading to main bearing wear and progressing failure.
As the bearings wear, they generate MORE HEAT, which causes metal "swelling," in the beaarings, and thus constriction.
As this problem slowly escalates, it gets to the point that the engine doesn't have enough power to continue to run, BUT...
After the engine has cooled down, it will run again.
IF this is the case in your machine, this problem can't go away, but will continue to escalate until the bearings finally fully seize!!!!!
May 06, 2014 | Garden
Engine runs great, accelerator responds perfectly, but the blades stopped moving. Any ideas?
Ensure blades are sharpened. If there are burs on blades they can seize.
Blades should be lubricated with WD40 , waste oil or other lubricant.
The bolts holding the two blades together shouldn't be too tight.
Apr 30, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I have a B&D electric Hedge trimmer that all of a sudden stopped working while it was being used. I've tried a different extension cord, I checked the outlet! The trimmer doesn't appear to make a sound...
have you checked the fuse? maybe it is burnt out and needs a replacement? If the fuse is ok, then you should take it back to where you purchased it from and you should be able to get a replacement or refund depending on whether you've still got a receipt, and the items under warranty. Hope that helped
Jul 07, 2009 | Black & Decker Black Decker 16" Hedge...
Remington Axcess hedge trimmer wont run at all.
Check your fuel lines. It is probably getting air into the system. Also check inside the gas tank to make sure the fuel pick up line is still attached.
If you need more assistance please provide an exact model number and I can better help you.
Kelly
May 10, 2009 | Remington Factory Reconditioned 17-Inch...
Black & Decker Black Decker 16" Hedge Trimmer Logo
485 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
