Question about Canon PIXMA MP160 All-In-One InkJet Printer
I had a paper jam and got the paper out but still shows E2
It was printing fine until I retrieved the jammed paper. After I pulled it out from the paper feed area where it was accessable, the print would no longer take paper through the paper feed. I continue to get an E2 message despite have attempted all the trouble shooting suggestions listed on the web site.
  • mrs_citroen Sep 20, 2009
    I had an E2. I contacted Canon and they confirmed that it is a mechanical problem. I am returning the unit and will get a coupon to purchase another Canon product. In the meantime, I needed a printer so I found an HP printer/copier for $70 bucks. Good enough for now.
  • 25 Answers
E2-2 = No paper (ASF)
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Posted on Sep 19, 2009
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
Canon MP145 Error 2
Just press the green (color) button about 5-10 seconds. Hope this help a bit.
Mar 25, 2010 | Canon Office Equipment & Supplies
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
My canon M 160 jammed, I pulled paper thru, now it won't print
E2 is "NO PAPER" error but in most case it's showing when the paper feed is in incorrect position.Check it movement correctly and check for any objects drop in printer.
Jun 14, 2009 | Canon PIXMA MP160 All-In-One Printer
Paper jam in my new Lexmark x2600 inkjet printer
Here's how to clear printer paper jam.
  1. Pull the paper out if it is visible. If not, then open the top of the printer so that the jammed piece of paper is visible.
  2. Grasp the paper and pull gently but firmly. If the paper continues to jam in the printer, inspect the rollers to ensure that they are grabbing the paper and pulling it along the paper path properly.
  3. Check the paper path for any obstructions, and clear if found. Also, inspect the other parts that the paper travels through, to ensure that they are not dirty or gummy. If any dirt or other debris is found, clean the parts and try again.
  4. Close the top of the printer.
  5. Place the printer back online. Try the print job again.
Just let me know for further assistant.
pincer
Apr 07, 2009 | Lexmark X2600 InkJet Printer
PAPER JAMMED-PRINTER HL5150D
Hello a_bowen1
You can clear the jammed paper as follows.
Note
    • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
    • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
  1. Pull the paper tray completely out of the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Press the cover release button and then open the front cover.
  1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
hl50_05712.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Note
    If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
chap0615.gif Caution
    After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
  1. Pull the Duplex Tray completly out of the printer.
  1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
  1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
hl50_047.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit assembly back in the printer.
  1. Put the paper tray in the printer.
  1. Close the front cover.
Good Luck and don't forget to leave a rating based on my solution:
Mark
Apr 04, 2009 | Brother HL 5150D Laser Printer
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
E2 Paper Jam code flashing .... but no paper jam!
There is a small sensor on the fuser that most likely has become disloged. It requires a lot of disassembly to get to.
But an E2 code is that sensor not being cleared off. It pops out of the frame sometimes during paper removal.
Apr 14, 2008 | Xerox WorkCentre XE80 Laser Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
1,117 people viewed this question
old marine
old marine
