Question about Refrigerators
Ice maker making cubes that are not completly frozen, botton of refrig is not cooling
    Problem Solver:
  • 10 Answers
Try to change, increase and adjust the thermostat.
Posted on Sep 13, 2009
Ice maker stopped working
Pour about 2/3 cup of water into the icemaker . After freezing , it dumps , replace the dual water inlet valve behind the refrig . If it does not dump the cubes , check that the coils are clean under the refrig at the bottom in front , and if they are and the freezer seems to cool good , then replace the ice maker . NOTE : If the ice maker dumps and not refil with water , replace the valve AND check the tube which fills the ice maker inside , to make sure ice has not frozen inside the tube , which also indicates a bad water valve ( seeps ( not closing completely )) .
Sep 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
No ice Ice maker does not fill up with water
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then check the fill tube going to the ice maker , to see if it is frozen up inside . If it is , replace the water valve behind the refrig , where the wall water line connects to on the refrig . If the ice maker dumps the cubes , but does not refill with water , then the water valve is bad . If the ice maker does not dump the cubes , then replace the ice maker .
Nov 11, 2009 | Refrigerators
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Oct 11, 2009 | Refrigerators
The ice maker on my refrigerator has stopped making ice. Water is still flowing but the tray doesn't fill and the whole mechanism seems not to function.
Pour about 2/3 cup of water into the ice maker . If the ice maker dumps the frozen cubes , but doesn't refill with water , you should replace the water inlet valve , behind the refrig , where the wall water line connects to . If the Ice maker does not eject the frozen cubes , replace the ice maker .
Also , check the ice maker fill tube , from the back wall inside the freezer , to the ice maker fill cup , to see if it's frozen . If so , you will need to remove it , and clean the ice out . This would be caused by a " seeping " bad water valve also .
Check the coils under the refrig , to make sure they are clean of dust , lint , pet hair , etc , as this will raise the freezer temp above 5 degrees , which is the temperature which the ice maker needs to operate properly .
Oct 10, 2009 | Refrigerators
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Ice maKer is not getting water but the water side works.
Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is not geting to the ice cube maker, it is
Look inside the water tube to the icemaker. It may be frozen. If so, thaw it out.
If not frozen, replace the water valve.
Mar 19, 2009 | Refrigerators
Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Nov 05, 2008 | Kenmore 53642 / 53644 Side by Side...
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
