Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
When tv goes to turn projectors on it powers off
When i turn the tv on i hear sound, but when it starts to turn the projectors on it shuts off, then i have to unplug it and plug it in again and the same thing happens
  • seymourmomof Sep 13, 2009
    it is a jvc 56 inch projection tv model number av56wp74
    Problem Solver:
  • 15 Answers
The main power transformer is either going bad or has bad solder points holding it on to the board. sometimes if it is a bad solder joint sound vibration from the speakers can cause the solder joint to disconnect and this inturns trips the system to power down. what make and model of TV?
try running the TV on Mute to see if it is a sound vibration jiggling a loose solder connection.
Posted on Sep 13, 2009
Samsung HLS5687.Replaced lamp,turned on TV the light goes on turns off. The projector boards continues to beep then tv powers off. Color wheel does spin. Not sure what the beeping is.
Did you check the ballast for the lamp? It provides the high voltage/energy to excite the lamp (no filament) into operation. If it does not work properly neither will the bulb.
Great set - I have the 5685.
Mar 06, 2016 | Samsung HLS5687WX/XAA
Lc4441 projector repair
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. Check to see if your TV is still under warranty first though.
Nov 29, 2014 | Philips Lamp for Philips CBRIGHT LC4441 -...
On my sharp pg f212xl projector when i turn it on i hear a click and the start up sound then i hear another click about 5 seconds later it shuts down and the power led blinks red
SORRY - it needs a new lamp. It is a protection for the projector so the bulb doesn't explode.
I purchase hitachi projectors with 3 year bulb warrenties now for our school as cheaper in long term
good luck
Jan 23, 2013 | Sharp ELECTRONICS PGF212XL PROJECTOR ...
No picture no sound power light on
you have to check the projector lamp it is installed somewhere behind the tv look for something that says lamp or projector and take it out very carefully and check it out if it is burned if it is then you have to changed start from there or you have a short in your tv that dosent give enough power for the tv to start up
Dec 19, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
T.V. SHUTS OFF - SCREEN GREEN WHEN TURNED BACK ON!!!!
is it a tv or rear-projector? does it brings out the sound?
on a tv it could be the chromatisation IC that is defectiven when it goes blank. why? because of a power surge in the electrical net the tv got too much voltage to take.
try to desoldeer the EPROM IC and power on the set. does this make the set goes normal blue screen? if YES,you can order a new EPROM IC.
succes and enjoy
Jul 17, 2010 | Sharp 13VT-R100 13 in. TV/VCR Combo
Samsung DLP TV HL-R4667W. When turned on, the TV comes on normally. Within about 10 - 20 seconds, the screen goes blank, can hear the sound for another couple of seconds, then can hear a relay trip, and...
Those lights flashing mean the lamp is the issue. You need to test it with a meter. If the lamp tests ok then it may be the ballast is bad and that is what powers the lamp.
Oct 12, 2017 | Televison & Video
EIKI XB23 PROJECTOR WON'T GO ON
Do you hear the fan start up? or does the projector lamp come on (you start to see an image)?
If yes to either:
When the temperature inside the projector reaches a
certain level, the projector will be automatically shut down
to protect the inside of the projector. The POWER indicator
is blinking while the projector is being cooled down. When
the projector has cooled down sufficiently (to its normal
operating temperature), it can be turned on again by
pressing the POWER ON-OFF button.
Note:
After the temperature inside the projector returns to normal, the
WARNING indicator still continues to blink. When the projector is
turned on again, the WARNING indicator stops blinking.
Then check the matters below:
– Did you provide appropriate space for the projector to be
ventilated? Check the installing condition to see if
ventilation slots are not blocked.
– Is the projector not installed near the ventilation duct of
air-conditioning equipment which may be hot? Install the
projector away from the ventilation duct of airconditioning
equipment.
– Are the air filters clean? Clean the air filters periodically. Let me know if you need to know how to do this.
If no to either:
When the projector detects an abnormal condition, it is
automatically shut down to protect the inside and the
WARNING indicator will be red. In this case, disconnect the
AC power cord and reconnect it, and then turn the projector
on once again for check. If the projector cannot be turned
on and the WARNING indicator emits a red light, disconnect
the AC power cord and contact the service station for check
and repair.
Please let me know if this helped solve the problem. If not, is there anything else you observed - whether or not you believe it's relevant.
1ak+f4pj7cbm32cuniyi2gaaaaaelftksuqmcc
Jun 26, 2009 | Optoma EP716 Multimedia Projector
Projector won't power up
the colorwheel is going. time to replace.
Jun 18, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
Powering down
I think you mean that you can still hear the fans running after shutting down, this is normal with the X family of projectors including the SP4800 and SP4805.
Feb 25, 2008 | InFocus ScreenPlay 4805 Multimedia...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
88 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
