Question about Dryers
Dryer is making a thumping sound as it spins - Dryers
  • 986 Answers
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Posted on Sep 13, 2009
  • 1073 Answers
SOURCE: My dryer is making a
not knowing the model but thumping usually means a tube roller issue
Posted on Apr 21, 2008
  • 1314 Answers
SOURCE: constant "thumping" sound when dryer is going
you can fix it by ordering a whirlpool roller kit but its no big deal the drum sits on rubber rollers when it just sits the rolers get flat spots on them like tires and makes the thumping sounds its just noisey but no big deal but they do make a kit with softer rollers
Posted on May 24, 2008
SOURCE: Thumping drum noise
ngfam1,
You are reminded, this is a SELF HELP web site. You are supposed to encourage people with you knowledge of how to repair appliances. Not to discourage them and tell them to call a repairman. The whole point of this forum is to AVOID a service call and NOT to promote your repair service. Give you a good rating for what? Stop begging for ratings and start actually helping!
Posted on Sep 06, 2008
  • 5 Answers
SOURCE: dryer makes a thumping noise when running.
replace drum wheels.
Posted on Jul 16, 2009
WonderTech
  • 268 Answers
SOURCE: Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Posted on Aug 12, 2009
I have a thumping sound in my dryer we put in new belt and wheels what can it be?
what's the brand name and model number?when it spins if you hear a thump thump as it spins that could just be the drum where the rollers hit it,i've heard that alot of times in dryers,i wouldn't worry about it,if it heats and spins and it doesn't sound like metal on metal or not making a real loud noise it's most likely just the drum,could be a little out of round and when the rollers ride on it you hear thump thump then when it spins you hear it again it will be fine,look at the drum,you might see some black stuff on it where the rollers ride on it,you can try cleaning it up it might help but i wouldn't worry about it.
Dec 26, 2017 | Dryers
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Thumping sound without spin
You can check the belt, pulley, and the motor
Feb 01, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Inglis dryer making thumping sound when drying
is the unit level, open the dryer try moving the drum around, see if the drum loose, there mite something in the machine that got caught on the drum some how and when it goes around it bangs,
you mite try spinning the dryer without turning it on and listen to the drum and see if you can hear any thing hitting the drum or what is make those load sounds. if you cannot turn the drum manually you mite bribe a guy or friend to check it out for a beer or glass of wine, and if they down drink bake some cookies.
good luck rod
Dec 04, 2012 | Whirlpool Inglis IP8200 Dryer
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Constant "thumping" sound when dryer is going
May 24, 2008 | Kenmore 63942 Dryer
Wont spin
many possibilities you may need chat help
May 07, 2008 | Frigidaire FDE336RE Dryer
Dryers Logo
285 people viewed this question
Top Dryers Experts
