Question about Olympus Stylus 600 Digital Camera
Cannot erase all
When I select Mode Menu and Card it won't allow me to select erase all.
  • 125 Answers
Is the camera reading the card correctly? If you can see all of the photos in slideshow view, then it should be ok. You can go to Format instead of going to delete to delete all of the photos. Simply format the memory card. It is an option in the camera menu.
Posted on Sep 13, 2009
I HAVE A NEW POWER SHOT SX130 IS (CANNON0 I DO NOT KNOW HOW TODELETE THE DOWNLOADED PICTURES FROM THE MEMORY CARD
You can delete photos from your SX130 IS in two ways:
To Delete Photos Individually:
  1. Press Playback Mode button (looks like a play button and is located on the top right on the LCD-side of your camera)
  2. The last image you took will appear on the LCD screen.
  3. Use the Left & Right arrow keys or turn scroll wheel to cycle through your images
  4. Once you find an image you want to delete, press the Trash button. The image will be erased.
  5. Press the Playback Mode button or the FUNC/SET buttons to exit when done
To Delete ALL Photos
  1. Press the MENU button (bottom right button on LCD-side of camera) to bring up the Menu screen
  2. On the Playback tab (Looks like a Play button icon), use the arrow buttons or turn scroll wheel to scroll down to Erase. Press the FUNC/SET button.
  3. You now have three options Select, Select Range, and All images. Select will allow you to delete individual images, Select Range will allow you to select a series of images, and All images will delete all images from memory. This last one is the option we are looking for.
  4. Use the arrow keys or scroll wheel to choose All images
  5. Use the arrow key or scroll wheel to select OK when the Erase confirmation screen pops up.
  6. Your images will be erased!
Mar 14, 2011 | Canon Cameras
I'm trying to find out how to delete all the pix on my camera at once. anyone know how?
hi, if you connect the camera to your computer and open the folders in file veiw you should be able to simple drag around them and press delete
Feb 11, 2010 | Olympus FE210 7.1 MP Digital Camera
Erasing the memory card;
All pictures in the internal memory and/or on the memory card can be erased at once. This is accomplished through either formatting or the "all-frame erase" function. I copied the following instructions from the advanced manual, which can be downloaded here: http://www.olympusamerica.com/files/d545zadvman.pdf. Adobe reader should open that file with no problem. If it doesn't, that's another issue altogether.
1. Enter playback mode by pressing the play button.
2. Press the OK MENU button.
3. Press the right arrow button (next to the lightning bolt) to access [MODE MENU]
4. Then, press the down arrow to access the [MEMORY(CARD)] tab.
5. Select the [ALL ERASE] function.
6. Select Yes and press OK MENU.
(You'll need to use the arrow buttons to navigate the menus. Please see pg 16 of the manual for instructions on how to do so.)
Note: when the memory card is in the camera, it will erase the pictures off the card. When the card is removed, the function above will erase the internal memory.
Apr 22, 2009 | Olympus D-545 Zoom Digital Camera
Cant unlock a picture
If you want them to be permanently deleted you can format the memory card and this will clear the card of all data. If you just want these certain images deleted then you need to be in Playback mode - press the Menu button - go to Playback menu and press Ok - then choose the key option and turn it from ON to OFF. This will remove the lock and allow you to erase the selected image.
Dec 17, 2008 | Olympus Stylus 710 Digital Camera
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Need to delete memory
You need to remove the memory card from the camcorder and place it into a pc or photo shops computer. This will allow you to view the saved items on the memory card. You can then save these to disc and delete the contents on the card.
Jun 12, 2008 | Optimus DV-5040 Camcorder
Deleting all photos
It's on <a href="http://www.fixya.com/support/p220497-olympus_camedia_c_350_d_560_digital/manual-2351/page-91">page 91</a> of the
<a href="http://www.fixya.com/support/p220497-olympus_camedia_c_350_d_560_digital/manual-2351/">User Manual</a>
In the playback mode (ie shutter closed and press "quick view") press "OK" (the centre button!)
select MODE MENU (right),
CARD (down twice),
CARD SETUP (right twice),
"ALL ERASE" should be highlighted, (up/down will toggle between "ALL ERASE" and "FORMAT"), with "ALL ERASE" highlighted press "OK",
press up to select "YES", then hit "OK".
That's it you are done.
Mar 22, 2008 | Olympus Camedia C-350 Digital Camera
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Formatting memory stick.
You can use the MEMORY FORMAT functions to completely delete all images and options on the Memory Card, including protected images. * The format function restores the Memory Card to its initial state. * The Memory Card supplied with this camcorder has been formatted already. Attention If you execute the MEMORY FORMAT function, all images will be erased completely and erased images cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The sub menu will appear. 5. Select FORMAT from the list and press the ENTER button. 6. "ALL FILES ARE DELETED! FORMAT REALLY?" appears on the screen. 7. Using the MENU DIAL, select the item. NO : To return to previous menu YES : To start formatting. 8. Press the ENTER button. If you selected the YES, COMPLETE! appears on the screen when the MEMORY CARD formatting is finished. 9. To exit the menu, push the MENU button.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Erase all my images at once
Please follow these steps if you would like to erase all your images at once. Use the arrow keys on the keypad to navigate through the menu. Steps: Turn Mode Dial to Play Back Mode (green arrow). Press "OK/Menu" button Select "Mode Menu">"Card" tab Select "All Erase">"Yes" Press "OK/Menu" button
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Olympus Stylus 600 Digital Camera Logo
46 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
