Question about Sharp LC-32SH12U TV
Picture goes on for 2 seconds then goes blank
Thomson flat panel tv has sound but no picture (comes on for about a second then goes blank)
if you can see if the screen lights from behind when the picture apears for a second then the problem is probably the invertor or worse the screen
Jan 06, 2013 | Thomson Televison & Video
Hp 2509m picture stays on for a few seconds then goes to Black
I had the same issue, It actually turned out to be the backlights themselves. An easy way to check this is by shining a bright light on the screen while its on. you should be able to see the picture.
Feb 20, 2012 | HP 2509m 25 in. TV
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Jul 04, 2010 | Albatron LNX-21TIS-3 Television
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Logik tv lcx27wn2 sound but no picture
the only info I could find on this is one withthe same problem. Replacingthe monitor had no effect and the store exchange it.
Jun 18, 2008 | Televison & Video
No picture yes sound
I was told that this problem could be the power board.
Jun 17, 2008 | Televison & Video
Maxent MX-27X2 no video,but sound
may not be the inverter but the main board bad
nesco
Dec 30, 2007 | Televison & Video
Sharp LC-32SH12U TV Logo
22 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
