Question about Cell Phones
LG Banter won't recognize music files on 2GB Micro SD card. Already reformatted card in phone before transfering files from PC via card reader. Can it only accept certain formats (ie mp3, wma,etc?) Any suggestions? Lisa J
How to transfer contacts from 306g to pc???
There is an option to export the contacts to the sd card.
Tap the contacts icon.
tap menu
look for import/export contacts
Tap export to sd card
you can select all or just the ones you want.
tap export then yes.
It will transfer them to a .vcf file and at that point you can transfer it to your pc via bluetooth or usb. You could also take the sd card out and use a card reader to get the file off. You will need a micro sd card adapter or a card reader that will accept that standard of card.
If you do not have a micro sd card ( look under the battery cover or on the sides for a small slot with a black card in it.) you will have to do the bluetooth or usb transfer.
Oct 12, 2015 | LG Cell Phones
I OWN LG COOKIE GD510!! I DON'T HAVE ANY BLUETOOTH IN MY PC.....SO HOW CAN I TRANSFER MUSIC IN MY PHONE VIA MY COMPUTER!!!????
1. Purchase a Micro SD card
2. Make sure you have a memory card reader for your pc if not buy one.
3. Plug in your memory card and memory card reader to the pc.
4. Drag music onto your card.
5. Put memory card back in your phone!
YOUR DONE!! :)
Enjoy
Sep 18, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Can't Transfer Photos From SD Card To Computer
were pic on camera before you started;if so it should work'
May 01, 2010 | SanDisk 2GB microSD Memory Card
I have a LG dare cell phone and want to transfer some pictures to my Laptop. Lap top is running windows vista 64 bit. when I connect the usb the pc does not recognize the usb connection. It recognizes all...
Well, for music...
Install the supplied software for your Dare on your computer.
In "My Music" select "Sync".
You can now see your Dare as a USB device but only music is accessible. :{
For photos the easiest way is to use a micro SD card and a card reader.
Store or move photos from your internal memory on your Dare to the micro SD card.
Transfer the micro SD card to your computer with either a built in card reader or a USB card reader.
The next alternative is to use a program like BitPim which can be a little tricky and can delete or copy all of your personal data (images, tones, contacts, etc...) depending on which button you press. The two buttons look very similar. Great way to download free ring tones and upload to your phone for free.
Oct 27, 2009 | LG Dare VX9700 Cell Phone
LG banter won't recognize data on SD mirco card
Please try to back up the music and picture that you have on the memory card, try to format the card using the phone before transferring the music and pictures again. Try to consider the memory capacity of the card, make sure that it is compatible with the phone.
Jul 09, 2009 | Cell Phones
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
Nov 13, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Cant transfer music file to my lg ku990 via usb from pc to phone
Instead of loading the music manager, click on file in the LG Suite box, and then click 'content'. This will connect without a problem (at least it did for me, despite music manager not working), and then drag and drop music from your pc files, onto your phone. Hope this helps.
Jul 27, 2008 | LG KU990 Viewty
Music player and micro sd card
I have found that mine didn't recognize songs if the name of the song was too long. Try going into Windows explorer (with the micro sd card in the computer) and rename at least one of the songs as a test. If that song is recognized by the phone, go back and shorten the names on the rest of the card. Good luck!
Sep 23, 2007 | LG VX8300 Cellular Phone
Cell Phones Logo
805 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
