Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
How do you get pip on yhe remote - Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
  • Sony Master
  • 1,525 Answers
Hello on the remote control there should be a button half black and half white pess that should give you pip good luck
shaun
Posted on Sep 13, 2009
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
Why is the picture in the lower left hand corner
It could be the picture within a picture is turned on. With only one input the main screen would be blank and the input with signal is in the lower left . Check out yhe P.I.P. settings . Hope this helps.
Dec 26, 2013 | Sylvania LC260SS1 26 in. LCD HDTV
Pip won't turn off. can the pip be removed or bypassed?
Some of the older sets with PIP require only the original remote to operate or turn on and off.
The PIP board usually develops problems with surface mounted caps and there is a "modification" where traces are cut and two 4.7 mfd caps inserted which will bypass the PIP board from the set--a model number would tell me if this is possible in your set or not--you missing the original remote? Almost any Mitsubishi remote of the era with PIP controls should do the job.
Dec 02, 2012 | Mitsubishi Televison & Video
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
Don't have original remote control. Somehow, a window for PIP opened, and I can't get it to turn off. Have a new sony remote RM-V310A, but the PIP button won't activate the remote. Any...
Many TV functions can be controlled from the on-screen menus using buttons on the TV itself. These include all kinds of settings however Sony did not include PIP in these menus. Therefore a valid remote is required to operate PIP. One thing you could try is removing the cable from the secondary input on the TV which provides the signal for the other picture. Without an input signal PIP may be disabled. Also, try buying a universal remote and setting the proper code for your TV. Original remote could be hard to find but remotes.com may have one.
Aug 05, 2010 | Sony KV-27S45 27" TV
I want to load my tv code from my vizio on my remote for my 321
I used 0178 to program my universal remote. You can also try 10056, 10178,10864,10885,11756,10056,11758, and 11499. Then you can try by dropping the "1" from the front of these codes.
Most good remotes have a programming function if this does not work, where the remote will "learn" the proper code.
The actual button remote codes are as follows:
0 00117
1 00121
2 00119
3 00123
4 00116
5 00120
6 00118
7 00122
8 00245
9 00249
Vol + 00183
Vol - 00187
Mute 00057
Channel + 00181
Channel - 00185
Power 00053
Enter 00164
Last 00247
Menu 00171
Guide 00244
Up 00168
Down 00166
Left 00170
Right 00037
OK 00164
Sleep 00054
PIP 00197
Info 00251
PIP Swap 00198
PIP Mode 00199
Exit 00216
Audio 00059
Input 00090
Wide 00138
TV 00110
AV 00105
Component 00231
HDMI 00174
MTS 00055
CC 00025
Zoom + 00165
Zoom - 00169
Freeze 00200
RGB 00253
PIP Ch + 00196
PIP Ch - 00203
PIP Input 00199
PIP Size 00201
Good Luck
Nov 30, 2009 | Vizio VW32L 32 in. LCD HDTV
I dont have a pip button on my remote to reset my
if you do not have the (PIP) button on your remote look for for the (split) button and try the volume down and (PIP/split) trick again. it worked for me!! good luck..
Oct 06, 2009 | Panasonic PT-43LC14 43" Rear Projection...
PIP WILL NOT GO AWAY
if you are using a cable box remote and the actual tv remote it is possible that both remotes have this option. check both remotes....
Feb 11, 2009 | Mitsubishi WS-55511 55" Rear Projection...
PIP DOESN'T WORK ON MY REMOTE drc800
I just looked this up myself. It said you have to have two tuners to get PIP. You can have PIP with another source like vcr or DVd with the TV.
That is all the manufacturer said.
Oct 02, 2008 | Motorola Mobility DRC800 Universal Remote...
Turning off PIP without remote
order the origanal remote from www.vancebaldwin.com the part number is RM-C380-1A the cost is $24.22 plus SH. there are a hand full of universal remotes that can control PIP but getting the right one a **** shoot.
Apr 19, 2008 | JVC AV-20120 TV
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
26 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
