Question about Dryers
TAKING THE TOP OFF A FRIGIDAIRE LEQ642DS0 STACKABLE DRYER
MY DRYER WONT HEAT UP SO I WANT TO CHECK THE HEATING ELEMENT AND THE THERMOSTAT.
FOUND A DIAGRAM SHOWING THE ELEMENT AND THERMOSTAT BEHIND THE DRUM WHICH MEANS I'LL HAVE TO REMOVE THE TOP, TAKE OFF THE FRONT, AND THEN REMOVE THE DRUM TO GET TO THEM I ASSUME.
BUT I'M STUCK TRYING TO GET THE TOP OFF. ANY IDEAS?
    President:
  • 744 Answers
Hello, there are metal clips holding the top down, push a screw driver under the lip on the front of the top about 3 inchs from each end, now lever it up at each end, it will pop up. You can then lean it back and take the front off, there are two screws 1 either side behind the front panel inside the machine. if you have any other questions please feel free to comment again. Good Luck!! Mike
Posted on Sep 13, 2009
Testimonial: "Thanks figured it out and used a butterknife. <laugh>"
Fer211as heats but wont dry! heating element comes on but kicks off after gets to temp then element will not come back on unless stopped and restarted?
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 22, 2011 | Frigidaire FER211A Electric Dryer
My frigidaire dryer LEQ642DS0 will not shut off by itself, would that be the timer or the knob? Also if it is the timer, is the kenmore/frigidaire part #131062300 (timer) compatable with my dryer
Instructions
Things You'll Need:
* Phillips and hex nut screwdrivers
* Replacement thermal fuse
* Replacement thermostat
1. Disconnect the dryer from the electrical outlet.
2. Slide a putty knife between the top panel and front panel on the left side. Slide the knife toward the center of the dryer to release the left-side spring clip. Repeat the process on the right side. Lift the top panel up and rotate toward the back of the dryer. The thermal fuse and thermostat are located along the dryer's back wall, attached to the heating element housing.
3. Disconnect the two wires from the thermal fuse. The thermal fuse is an inch-long rectangular plastic part, located near the top of the heating element housing. Remove the screw holding the thermal fuse in place. Remove the old fuse. Place a new fuse on the housing and replace the screw. Reconnect the wires to the fuse.
4. Remove the wires on the thermostat. The thermostat is a black, oval-shaped part located just below the thermal fuse. Remove the screws holding the thermostat in place and slide it out of its slot on the heating element housing. Slide a new thermostat into the slot and replace the screw. Reconnect the wires.
5. Lower the dryer's top panel and press down until the spring clips lock into place. Plug the dryer back into the electrical outlet.
Feb 24, 2011 | Frigidaire Dryers
Dryer runs but no heat. Stackable set, dryer on top.
More than likely the Thermistors are blown. They are located on the heating element canister inside the dryer, they are kinda oblong shape with two electrical connections. If you have a multimeter you can check for continuity on the thermistors and the heating element just be sure to disconnect one of the electrical connections on the thermistors and the heating element so you don't get a false meter reading, Thermistors can be purchased from most appliance repair businesses for around $30.appliancguru.jpg
Dec 10, 2010 | Frigidaire FGX831CS Top Load Stacked...
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire Dryers
I have a stackable washer/dryer whirlpool model #WET3300SQ1. Heating element in dryer is not heating. We have replaced the heating element and it is still not working.
if you dryer is gas check out this gas no heat tip....
check out this electric no heat tip...
heatman101
Aug 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
Daryer is not heating
The heating circuit of the electric dryer consist of the following parts. The timer, the heating element, the hi-limit thermostat, the safety thermostat, the operating thermostat, the temperature switch and the motor centrifugal switch.
If any of these parts fail, the dryer will not heat. Now, most people when the dryer stops heating, replace the heating element or the timer with out checking to make sure that those parts are bad. Rule number one is, don't assume that the part is bad with out checking it with a multimeter.
The first and most important thing you need to do, is to disconnect the dryer from the wall outlet before doing any kind of work on it. Most parts will need to be checked for continuity and the dryer must be disconnected from the wall outlet.
Most of the times the part causing the problem is behind the dryer and you can gain access by removing the back panel.
Remove the back panel on the dryer. Disconnect one of the heating element wires and take a reading between the two terminals on the heating element. The reading should be between 10 and 50 ohms. If the heating element is good, check the hi-limit thermostat by removing one of the wires and checking for continuity. Continuity means, that electricity could pass through the part that you are checking.
The hi-limit usually blows when there is an obstruction on the exhaust hose, so make sure that the exhaust hose is not obstructed when replacing the hi-limit kit.
If the hi-limit thermostat and the heating element are ok, check the operating thermostat. The operating thermostat is in charge of maintaining the temperature inside of the drum at about 150 degrees. You will need to check from the two terminals with the red wires attached on it.
Those where the parts that fail more often in the Whirlpool electric dryer. The timer, the motor centrifugal switch, the temperature switch are a little harder to check because there are may different one. You will need to use your wiring schematic to see how to check them.
Aug 17, 2010 | Frigidaire GLER341A Electric Dryer
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Dryer has no heat
either your heating element or your thermostats are bad. on the heating element casing there are two thermostats. check the top one for continueity if it doesn't have continueity the change both thermostats. if they are good then check your heating element for continueity. after you get your dryer heating then clean out your vent system... if it's not venting properly then your dryer will take a long time to dry.
Jun 16, 2009 | Frigidaire Dryers
Dryers Logo
235 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
