Question about White Sewing W750 Mechanical Sewing Machine
White w750 sewing machine
I am having trouble adjusting my tension. Any ideas. Bottom and top seem to be messed up. Thanks
  • 35 Answers
I would suggest removing all of our thread and rethreading your machine. Put the thread tension at medium. Try a few stitches. If they are unacceptably loose or tight, try loosening or tightening the bobbin's tension. To do this, locate the tiny hole at the front of the bobbin area. This hole is on the outside of the machine. This hole lets you have direct access to the bobbin's tension screw, so find a tiny screwdriver and turn the screw inside the hole a little to the right for tighter tension, or to the left for looser tension. Let me know how it works - I love this sewing machine!
Posted on Aug 16, 2008
Tip
How to adjust the tension on your sewing machine
Few things are more frustrating than not being able to get the tension on your sewing machine balanced. Here are a few tips on how to do it:
1. Make it a habit to thread your machine with the pressure foot UP. This disengages the tension disks so the thread is able to slip easily between them.
2. Always adjust your machine's tension with the pressure foot DOWN. If it's up, although the numbers on the tension dial may move, the tension settings on the disks don't.
3. Remember that the numbers on the tension disks are relative. Generally, "3" is a good place to start, but it's only a number. Increase the numbers to tighten the tension, decrease them to loosen it.
4. Use different color threads in the top and in the bobbin to make changes easier to see.
5. Sew a few inches, stop, and examine the stitches. Adjust the tension just a little, stitch a bit more, then examine again. Repeat as needed until there is no (or very little) of the top thread showing on the bottom fabric and no (or very little) of the bobbin thread showing on top.
But how do you know which way to adjust the dial?
This is where a lot of the confusion seems to come from, because it 'seams' backwards! Look carefully on the bottom, the bobbin side. If you're using the same color threads both on top and in the bobbin, it can be hard to see, but usually what you'll see if you have 'loopy' threads on the bottom, is that the loops are actually the top thread and that the bobbin thread is laying on top of the fabric. Using different color threads makes this obvious.
What's happening is that the top tension is too loose, so it's not pulling the bobbin thread up into the fabric.
There's a tendency to see the loops on the bottom and think the bobbin tension needs adjusting, but the real problem is with the top tension. (There is a bobbin tension adjustment but you shouldn't have to mess with that very often, if at all.)
I've posted a couple of photos at www.robbiesews.blogspot.com so you can see what I mean by balanced tension.
Happy Sewing!
on Mar 10, 2010 | Sewing Machines
Tension settings
Some general suggestion - not familiar with White. If you know where the tensioner is, take a scrap of relatively stiff cloth in a constrasting color to the thread to make it easier to see. A good stitch tension will look like a line of adjacent dashed on top and dash-dot-dash on the bottom. If you are seeing dash-dot-dash on top and Dash-dash on the bottom, the tension is too tight. If - usual case - the bottom has dash-loopyloop-dash, or worse, snags, the tension is too loose. Remember tension may need to be adjusted for thicker or thinner work.
Jan 20, 2014 | White Sewing 1418 Mechanical Sewing...
Tension is messed up on my 96ksv7
Keep adjusting the tensions top and bottom until you get it right
Oct 27, 2013 | Singer 3116 Simple
New Home ss2015 machine. I am having trouble with the thread tension. I have loops on the bottom. I have cleaned the bobbin case, changed the needle, re-threaded and moved the upper tension all the way up....
try adjusting the top tension to 3 & if it doesn't stop the looping, try 4 but I wouldn't go any higher than 5,, if changing the top tension doesn't help then I suggest taking the machine in to have it serviced. the bottom tension is more difficult to do,, it's also very possible that the top tension dial is messed up & needs replacing. only a sewing machine shop can tell for sure.
Mar 02, 2012 | Sewing Machines
When you stitch a piece of cloth, the stitching appears to be loose, resulting in a very untidy stitch.please help immediately.i didnt get a booklet with my sewing machine
Firstly you can download a manual from the Singer website, link is
http://www.singerco.com/accessories/instruction-manuals, type in "W750" and click search.
Once youve got the manual downloaded, I'd suggest you print it out and get it bound in covers so it can stay with the machine.
Then trouble shoot the tension, this sounds to me like you've got insufficient or no tension on either top, bottom or both threads. You need to revise the threading up and make sure you always thread up the top with the pressure foot raised so the thread properly seats into the tension discs. Set top tension on the normal mark between 3 and 4 and make sure when you load the bobbin into the bobbin holder, that the thread gets clicked into the tension spring completely.
Now test sew again, and tighten up the top tension a fraction if it shows on the underside. You can't adjust the bobbin tension on these machines or at least the manual doesn't show any adjustment, just says to adjust the top thread tension.
As a rule of thumb, change your sewing machine's needle for each new sewing project too as this will help with stitching quality.
If you can't get it looking any better consider taking the machine back to the shop (if its fairly new) and getting it checked.
If you are planning to sew lots of things, you may want to consider buying a higher level quality machine than this one, it is an entry level machine and there is huge variation in stitching quality between the cheaper models and the higher end quality ones. Just depends on your sewing needs and desires I guess as to whether its worth investing more $$.
Sep 21, 2011 | White Sewing W750 Mechanical Sewing...
I have a White 7140 quilters sewing machine. I can't find the manual and I am having trouble threading it. The stiches are coming out loose on top, but ok on the bottom. I have tried adjusting the...
try http://www.singerco.com/accessories/instruction-manuals and search by typing in your model number. I couldn't see it there but there are other white machine manuals there so maybe one will give you help with threading. It sounds like the bobbin thread is not under tension, usually if the top is loose it is the bottom thread which is not tensioned and visa versa.
May 30, 2011 | Sewing Machines
Have been trying to adjust the bobbin pick up and seem to get that part the the thread gets caught in the bobbin mech or knots up on material
try to rethread top and bottom, and make sure the thread is seated in the top tension disc. I have owned a few Whites and had a lot of timing issues with them
Aug 14, 2010 | White Sewing 1418 Mechanical Sewing...
Pfaff 1475 tension problem.
Many users also reported similar bobbin tension adjust problems. But do you know it can be fixed by yourself? I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Jun 21, 2009 | PfaFF Tiptronic 2030
Euro-pro 464xc bottom tension loose
Welcome to FixYa!
Loose bottom stitches come from the top, not the bottom. Seems weird, but that's the way sewing machines work.
The dial tension should be set at the mid range and make absolutely sure that you have the machine threaded correctly. Both things will cause a sloppy bottom stitch.
Thanks!
If you find my solution helpful, I'd appreciate a FixYa rating....
Jan 15, 2009 | Kenmore 12102
White Sewing W750 Mechanical Sewing Machine Logo
160 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
