Please help, got something that is infecting my computer but no scanners can detect it, i'm trying to run malwarebytes antimalware, but when you hit start scan the program just closes, there is an infection on my computer that is preventing scanners from running, however i can get online and browse the web, but when i use google to do a search for something, it brings up the results but when i click on the result i get redirected to something else, totally non related... i have checked device manager for non plug and play devices and there is no TDSS in the list, someone online said to check for that, tried renaming the malwarebytes executable and that doesn't work either the program still shuts down... i have ran process explorer to see whats all running for active processes but nothing suspicious is listed even under explorer.exe... . please help as i don't want to restore my whole computer, too much work and don't want to lose data... i just want to get rid of this nasty bug and get my computer working normally again... thank you so much
  • 5 more comments
  • steffensco Sep 13, 2009
    i'm sorry but this did not work, it scanned, but no detection... computer is still behaving strangely... still google is not working... please help, thanks
    please help, got something that is infecting my computer but no scanners can detect it, i'm trying to run malwarebytes antimalware, but when you hit start scan the program just closes, there is an infection on my computer that is preventing scanners from running, however i can get online and browse the web, but when i use google to do a search for something, it brings up the results but when i click on the result i get redirected to something else, totally non related... i have checked device manager for non plug and play devices and there is no TDSS in the list, someone online said to check for that, tried renaming the malwarebytes executable and that doesn't work either the program still shuts down... i have ran process explorer to see whats all running for active processes but nothing suspicious is listed even under explorer.exe... . please help as i don't want to restore my whole computer, too much work and don't want to lose data... i just want to get rid of this nasty bug and get my computer working normally again... thank you so much
    yes i have tried this, it shuts down the program when i began to scan, i have tried running malware bytes antimalware, tried running spybot, when you click on start scan on either program, the program just closes and you can't scan, then when you try and open the program again it gives you an error about something to do with you don't have proper permissions.... this infection is something i have never seen before, i'm downloading the fsecure online scanner right now and trying to run that to see if anything happens, but is there anything else i can do to get rid of this darn thing... thank you
    system restore is turned off for performance reasons, no restore points are available to restore back to, scanners will not run, the infection is shutting then down upon launch...
    still no luck my friend, tried your solutions, the only item that i have starting up thats in the startup list is the avg software, but this won't scan and neither can i get malwarebytes antimalware to scan, the infection is just auto closing these programs whenever you attempt to scan....
  • 15,935 Answers
Restart your computer in "safe mode with networking" by tapping f8 after powering on the PC. use FSecure's FREE online scanner CLICK HERE It should do the trick for you. Thanks for using FixYA!!
Posted on Sep 13, 2009
    President:
  • 2,923 Answers
Do you still remember when the computer started to act like this? Do you remember any program that you installed before it happens? If you do, the only thing that I could think of is to perform a System Restore.
Doing a system restore would erase the program that you installed or run and that should fix the problem.
To do this, please follow the steps below:
Click on Start > All Programs > Accessories > System Tools > System Restore.
NOTE: Performing a system restore would allow you to select the date that you would like. All programs that were installed beyond that date would be erased.
I know that this would help you. Have a great day!
  • 4,281 Answers
First go to start menu then type in run "services.msc"
then you see all services .
Check in righr pane you find DND client right clicko n it then stop and then start again it.
then check.
Also go to start menu then run type in run "msconfig" then you see system configuaration utility.
Go to startup disable all then restart computer.
Then try to scan your computer.
Let me know if you need more assistanse.
Thanks.
    President:
  • 333 Answers
Have you tried running your scanning software from Safe Mode?
  • Superbovine Sep 13, 2009
    If your scanning software is up to date and not finding anything in Safe Mode, it may be registry settings that have been changed creating this problem.
    Have you tried running a System Restore back 2-3 days before this started?
    Wow, that's bad news. System restore should not effect your performance to any appreciable degree.
    The only thing you can do at this point is make a list of your running processes to evaluate what might be suspect, and make a list of all applications being run at startup.
    You can find your startup applications by clicking Start, Run, then typing MSCONFIG and hitting enter.
    On the window that pops up, click the "Startup" tab and make a list of the items.
HELP IT SAYS MALWARE WONT LET ME IN MY FACEBOOK ACCOUNT FROM MY AOL ACCOUNT I DIDNT ORDER OR WANT IT
If you have malware, get
Malwarebytes ' Free Anti-Malware Detection & Removal...
from
www.malwarebytes.org/antimalware
Malwarebytes Anti-Malware's industry-leading scanner detects and removes malware like worms, Trojans, etc...
Only download any software from its official site, not C/Net, Downloads.com etc... These will put malware on your computer.
Mar 23, 2015 | Facebook Computers & Internet
Windows has been detected spyware infection
You can download "malwarebytes anti-malware" onthis page:
http://www.malwarebytes.org/mbam.php
Download and install it, update and run a scan. Follow steps to cleaning.
If this helps or solves the issue, please rate it and give a testimonialfor my response.
Feb 28, 2011 | Computers & Internet
My sony viol ltop is infected with trojan horse virus
Then use your antivirus and malware scanners.
If you dont have any, try.
AVG9 Free or microsoft security essentials
Plus Malwarebytes antimalware (free version)
Your best running the scans in safe mode ( F8) also turn off your system restore when you scan, you can turn it back on when the scans finish.
Sep 05, 2010 | Sony Computers & Internet
My pc is infected
Try to clean your pc with professional antivirus software and remove the infections. For now you can use the free utilities
Kaspersky - http://support.kaspersky.com/viruses/utility
It contains good virus removal utilities for free and Kaspersky Virus Removal Tool is the best download it for free.
Malwarebytes Anti-Malware - http://www.filehippo.com/download_malwarebytes_anti_malware/
It is also a good software that can detect and remove malware that even the most well known anti-virus and anti-malware applications fail to detect.
SuperAntiSpyware - http://www.filehippo.com/download_superantispyware/
Detect and Remove Spyware, Adware, Malware, Trojans, Dialers, Worms, KeyLoggers, HiJackers, Parasites, Rootkits, Rogue Security Products and many other types of threats.
Windows Defender - http://www.microsoft.com/downloads/details.aspx?familyid=435bfce7-da2b-4a6a-afa4-f7f14e605a0d&displaylang=en#Requirements
Windows Defender is a free program that helps you stay productive by protecting your computer against pop-ups, slow performance and security threats caused by spyware and other potentially unwanted software.
Microsoft Security Essentials - http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=e1605e70-9649-4a87-8532-33d813687a7f#Requirements
Microsoft Security Essentials provides real-time protection for your home PC that guards against viruses, spyware, and other malicious software.
If this doesn't solve your problem give me a feedback with more details, this helps to solve your issue.
Jul 21, 2010 | Microsoft Windows XP Professional SP2
Security tool adware blocking Panda antivirus download
You can start your computer in safe mode with networkin
>> Tap F8 key as soon as your computer is starting up to go to safe mode with networking .
Try downloading Malwarebytes Antimalware from
>. run a full scan
once the scan is completed click on show results and remove the infection
>. on Malwarebytes click on the quarantine tab on the main window and delete all the infection from there
>> restart the computer
Apr 12, 2010 | Panda Antivirus Pro 2009 - 3 User for PC
I get the clean virus.vb error report every time i reboot my laptop and from past three days the audio sound of the laptop is also disturbed
Use the following link to download trial version of Antimalware (do not purchase anything)
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
Click on green colored Download Now button.
Once downloaded, Install it and scan your computer.
Select Perform quick scan, click on Scan
When completed, it will give you the option to Remove Selected (if it finds any infection)
Let me know if Antimalware is able to detect any infections.
Mar 09, 2010 | Sony VAIO VGN-FJ270/B Notebook
I cant access certain websites can you help
To identify the problem, use the following link to download trial version of Antimalware (do not purchase anything)
Mar 09, 2010 | Microsoft Windows XP Home Edition
Sony Vaio VGN-FZ320E is inundated with viruses, only operates in safe mode, will not accept new virus protection, and I have no Vista recovery disc. How can I download one, or will I have to wipe it...
Just sharing this,
Try to inquire on sony support. If you can have the recovery cd, usually they will charge for shipping. Have it and your hand its better you have a good fall back to restore your lap on factory settings.
But for your virus infection. You have at least a chance to purge that out of your system since you can boot on safe mode.
You can try to use combo disinfection. Like ;
1. AVG
2. Ad-aware
3. Superantispyware
4. Malwarebytes antimalware
5. Easy cleaner
6. Avast
7. Combofix
8. Mcaffee Stinger
Use combofix on safe mode but this could also do some corruption on your system this is for the last resort if ever.
Try to look for antivirus that can run on safe mode on the list, and do some research how it works best.And also try to backup your important files and installation files first before running the antiviruses. And also run antivirus one at a time. Then try to record what virus hits you.
This maybe an overkill. The reason is you don't know what virus infects you then try this antivirus who can distinguish it and run on safemode. The reason I sharing this is it will just infect you easily again even you restore it to factory installation. " Prevention is better than cure".
If ever you disinfect the virus using this, then pick one antivirus that disinfect this infection and uninstall the other. I also recommend Malwarebytes antimalware on the system together with one antivirus.
Goodluck
Oct 08, 2009 | Sony VAIO VGN-FZ320E/B Notebook
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
