Question about Brother HL-2040 Laser Printer
Same prob as sphil4988 11 Sep09 - RED PAPER LIGHT REMAINS ON EVEN IF NO PAPER JAM, THERE'S PAPER ON TRAY, UNIT IS CLEAN. THANKS FOR YOUR SUPPORT.
    Scholar:
  • 136 Answers
Check the Paper Sensor if it is in the Upright position or broken off it will keep asking for paper
check that sensor.
Posted on Sep 13, 2009
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Red flashing light still on even after replacing p4014n catridge
Could be a paper jam inside the machine(pick up: between the tray and cartridge compartment or EXIT: Between fuser and EXIT UNIT.
ALSO could be BAD SEPARATION ROLLER IN THE PAPER CASSETTE TRAY and UPPER SEPARATION ROLLER OR BROKEN FUSER. Question? call 917-359-7432
Jun 10, 2014 | HP LaserJet P4014n Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Red paper light is on even though there is paper in the tray. brother 2040 model.
This is a paper jam. Remove paper try as well as the toner/drum unit. Take vacuum and clean out inside the printer. Separate the toner & drum units and vacuum-blow out the drum unit to get it clean. Run the drum wire cleaner tab (purple/blue tab at front of the drum unit) back & forth a number of times. Sounds like you've got a piece of paper stuck inside somewhere. In the back of the printer, there is a door that will open out and down...check here for a speck of paper that is causing the paper light to come on...it "sees" something is in the way) since this is where the paper curls up and out the top. Reassemble toner/drum unit. Before you put the paper tray back in, take a piece of paper and feed from the front (use light card stock or heavy weight paper since this will help push out anything inside that's in the way) and print a few pages this way. Then, make sure your paper is dry (hasn't been in humid area) and is lying flat (not curled at edges). That should do it
Dec 21, 2009 | Brother HL-2040 Laser Printer
Status light remains red
download smarrt panel from samsung website,install on pc and run.have printer connected.will resolve issue.
Jul 06, 2009 | Samsung CLP 300 Laser Printer
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Dell 1110 Laser Printer Solid red warning light
Hi in this case the paper jam made some sensor through the paper road they are not in normal position or still tigger on by piece of something or error stander. you may try:
1) check paper input sensor near paper tray roller\
2) check margin sensor inside paper way before drum unit
3) check fuser sensor near fuser unit
4) check paper output sensor near output tray roller
sometime need sensor adjustment back to normal position
Dec 22, 2008 | Dell 1110 Laser Printer
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Brother HL-2040 Laser Printer Logo
128 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
