Question about Canon PIXMA MX700 All-In-One InkJet Printer
MX700 won't scan or copy
My mx700 goes through the motions of scanning, but it won't output a scan file. It also appears to scan when copying and pulls paper, but there's no print on the output. Replacing the ink cartridges didn't help either.
Scanned documents too light
Might try jet clean cycle. Ink might be old or off brand. What is the brightness code # of the printer paper? The higher the # the brighter the page.
Apr 01, 2014 | Canon PIXMA MX700 All-In-One InkJet...
How to scan a legal document using the Canon MX700 printer
The image below should help you! It was taken from the Canon PIXMA MX700 Quick Start Guide.
If you want to edit the scanned image or scan originals with advanced settings, see the Scanning Guide on your on-screen manual.
Jul 03, 2012 | Canon PIXMA MP830 All-In-One InkJet...
Cannot get my Canon MX700 to Scan. Also did not get a Guide.
You need to install scaning software that came with the printer to scan and save the file to your PC,Out going faxes should not be an issue if you can copy.Once you install the software tell the program where you want it to save the file in ex: My Documents.During set up you can do this (you can change anytime as well as dpi resolution).Windows has built in scaner set up. Go to start, control Panel, Cameras,scaners.Good Luck.
Sep 19, 2009 | Canon MX700 Office All-In-One InkJet...
Canon MX700 scanner wont scan
just uninstall the driver software and re install it.
Sep 09, 2009 | Canon PIXMA MX700 All-In-One InkJet...
How do I scan copies to the computer?
The software and user guide is available at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15651
When running the software you should be able to select scan and feed in the pages. Good Luck
Jul 28, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5100
5100 means either there is paper stopping the carriage from moving properly, or there is grease on the plastic strip behind the carriage. If you wipe off the grease with a Q-tip the error will go away.
Jun 24, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Scanner on Canon Pixma MX700 doesn't work
hi dear
try using another software like photoshop
or acd see
oke
Apr 03, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA MX700 All-In-One InkJet Printer Logo
163 people viewed this question
old marine
old marine
