Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Freezer defrosted everything- fridge seems cold-
Smell a slight burning--all lights are on and everything seems fine
  • Whirlpool Master
  • 1,606 Answers
Sounds like the overload/relay is bad . Pt# 2188831 . This is the part attached to the side of the compressor , with 2 or 3 wires connected to it . Easily replaceable . Also , make sure the coils under the front of the refrig at the bottom , is clean of dust , lint , pet hair , etc.
Posted on Sep 13, 2009
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Fridge had a lot of frost at the back (top fridge/lower freezer), turned it down and it defrosted, however, the freezer doesn't seem to be working properly either. Defrosted it all last night and this am...
It sounds as if the freezer coils and vent stack are frozen solid. This usually requires
removing the back panel in the freezer compartment and defrosting carefully with
a hair dryer. (If this becomes frozen it blocks off the fan/vent that feeds cold air down to
the fresh food compartment) Make sure to unplug unit before servicing as you will need
to unplug the fan to remove the back panel.
While doing this check the defrost termination thermostat (a small device attached to
the tube with two wires coming out of it). The black plastic ones sometimes come apart
and fail.
Once defrosted put everything back together and test.
Hope this helps.
Mar 15, 2011 | Refrigerators
Ge freezer works fine but the fridge wont cool.you
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
Fridge not cold as should be
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
Aug 29, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Fridge side is not cooling, freezer side is fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 08, 2009 | Refrigerators
Fridge not cooling! But the Fan and light is working! HELP!!
Sounds like you have caused a leak in the sealed system and the coolant is no longer inside it. You will need a professional to fix this.
Apr 13, 2009 | Jason Natural Cosmetics Jason Forma...
KGU 34641 GB TOP REFRIGERATOR
Hi,I believe you may have a blockage in the intake from the freezer to the fridge as cold air is blown up from the freezer to make the fridge coldhope this helps,mike,
Aug 10, 2008 | Bosch KGU34641 Bottom Freezer Refrigerator
Freezer working fine, but no cold air to fridge
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control unit
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
179 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
