Question about Briggs & Stratton Garden
Watery oil dripping from air filter
I have watery oil dripping from air filter. What do I need to do to fix this?
    Problem Solver:
  • 6 Answers
Must be an older unit. This sounds like blow by and there is not much you can realy do about it short of completely rebuilding the motor.
Posted on Sep 13, 2009
Coffee started being super watery, why? Can we fix that?
HI - Be sure you are using the correct filter for your machine. Also and very important is the ratio of coffee to water. The measuring device too matters. Some manuals state: a tablespoon -- some folks heap it on, some make it perfectly level and it all matters.
You may need to experiment to get it right. If this happened all of a sudden, it may be the machine not allowing the drip rate to be slow enough or something.
HTH - Fred
Sep 09, 2015 | Coffee Makers & Espresso Machines
Oil in airbox
Hi, Anonymous oil leaking from your air cleaner is caused by oil carryover from the engine. For whatever reason, the breather system is not separating enough oil mist and air from the piston downstroke. There are cheap and quick easy fixes and there are more expensive ones. First, make sure your breather hoses are not dry and cracked if they are ok you can start by trying the following:
1. Run your oil level half way between the add and full mark when hot.
2. Run oil breather lines from the head into a TEE fitting below carb/induction module then a single line into a mini filter under the frame.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Oil Dripping Out Of Airbox Workshop Help
Re help oil dripping from air filter Road Star Forum Yamaha Road Star
1999 2003 Yamaha XJR1300 Service Manual Moto Data Project
OEM parts for Yamaha
http://www.yamaha-xjr.cz/download/owners_manual_2001.pdf
May 20, 2014 | 2002 Yamaha XJR 1300
Leaking water after stopping
Liquids in an auto..... Antifreeze (greenish/clear, watery, with slight oil feel to it, smells somewhat sweet), Power Steering Fluid (very thin oil, usually red tinted), Brake Fluid (very thin oil, clear), Transmission Fluid (very thin, red and kinda of sweet smelling), Motor Oil (amber colored or black, medium viscosity, usually smells acidic), Washer Fluid (usually water). Only other fluid is condensation that drains from the air conditioning drain pan after driving the car and the air conditioner has been on.
It can only be one of the above, really need a lot more information, to even begin to make a guess.
Dec 17, 2012 | 2001 Buick LeSabre
Leaking oil from somewhere near air filter box on 05 YFZ 450
How much oil does the air filter have in it? If it's over oiled, it will drip into the box and fill up the drain plug. The foam filter that comes with our atv requires oil to trap dirt. Some people unknowingly will apply too much oil and it will drip, especially when it's hot out. Take the filter off, clean it with Dawn Dishwashing liquid. be sure he filter is dry, then re oil. I like Uni oil in he aerosol can. Spray it evenly but not too much, then rub it in with your hands, have a rag ready.
Nov 19, 2012 | 2004 Yamaha YZ 450 F
2003 sunfire using oil - oil in air box by throttle body - where is pcv valve located
Check and or replace your PCV valve. also make sure the oil level is not overfilled.and your airfilter is not dirty/plugged
Aug 26, 2012 | Pontiac Sunfire Cars & Trucks
Oil leaking from back of air filter
Hi Robert, oil leaking from your air cleaner is caused by oil carryover from the engine. For what ever reason the breather system is not seperating enough oil mist and air from the piston downstroke. There are cheap and quick easy fixes and there are more exspensive ones. Start by trying the following:
2. Run oil breather lines from head into a TEE fitting below carb/induction module then a single line into a mini filter under frame.
3. Purchase Arlen Ness Super Sucker.
4. Replace umbrella valves and realign oil pump
5. Upgrade oil pump and cam plate
Good luck
Jul 19, 2012 | 2002 Harley Davidson FLHR - FLHRCI Road...
Twice now the engine has flooded. When I took off
clean that carb-pull float cover down and inspect--is the fawcett on prime then it will pour--chec oil for smell of gas or feels thin--engines need exercize like us to keep healthy
Jun 25, 2010 | 2005 Honda VT 750 Shadow Aero
Very heavy smoke from exhaust of Yamaha Virago 250ccobviously smells of burnt oil.doesnt seem to have any rattle or loss of power just belches out blue smoke.
give the air filter a blow out m8,, and change the plugs to a hotter grade,, ie if u have ngk b8es or summat try b9,,that type of thing,
Apr 10, 2009 | 2000 Yamaha Xv 250 Virago S
Oil leak
and with the V50 I thought I'd achieved my ambition. It was oiltight to begin with but not long after I'd done a bit of maintenance (oil and air filter change) I started noticing drips underneath - coming from the pipe that dangles from the air filter unit (yes it still has the original [expletive-deleted] item). For a while I ignored it as there were so many other jobs needing to be sorted, but it has just got worse. After a long trip, parking it is embarrassing - especially as everyone knows that Guzzis are oiltight . . . Now it seems to me that the oil could have come from one of three places - the crankcase, or either of the rocker boxes, as all of their breather pipes go to the underside of the air filter chamber. I therefore detached the existing pipes to the rockerboxes, stopped up their ends, and ran new breather pipes from the rockerboxes to vent under the bike. I reckoned that, with three pipes dangling underneath (Sherlock Holmes' three-pipe problem?), I should be able to see which part of the machine was responsible. With me so far? Did a 21-mile trip this morning, put it back up on its stand and waited. Result - oil drips from all three pipes! Thinks: when bought, the oil level was only just above minimum on the dipstick. When I changed the oil, I filled it to the max level - and someone has suggested that this is the cause of the problem. I therefore drained some oil out, and it's now at the half-way mark though without any effect on the oil drips. I'm reluctant to drain more, though that might be the next step. If it does effect a cure, would that point to some other, underlying problem? Any ideas or suggestions welcome, as at the moment this machine is not living up to the Guzzi reputation.,The breather system on the V50 works in a peculiar way. The two pipes from the rocker covers are the main engine breathers. They go into a chamber in the air filter housing, and the tube from there to the crankcase is actually a return pipe, to get the oil recovered from the breather back into the sump. On mine, I am sure the breather then goes into the air box behind the carbs, and I didn't think I had another pipe dangling down. Certainly too much oil in the sump can cause problems in most Guzzis.,,,
Nov 10, 2008 | 1981 Moto Guzzi V 50 II
Garden Logo
133 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
