Question about Ovens
My magic chef oven flashes F-5 when we try to turn on the oven!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F5 means Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
ERC - Electronic Range Control. Watchdog - a combination of hardware and software which acts as an internal scheme, disconnecting the systems output from the process in the event of a malfunction.
Turn off the Oven for 2-3 hours, the oven will reset itself. However, if the error still persists then follow the procedure to troubleshoot the error code--
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F5 and listen for the beep.
  • If you get the F5 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F5 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Posted on Sep 15, 2009
Testimonial: "yES THIS WAS HELPFUL BUT i HAD ALREADY FOUNG THE ANSWER AT ANOTHER SITE THE DAY IT HAPPENED, NOT TWO DAYS LATER."
I have a magic chef electric wall oven and it flashes an error code of F3 when I try to bake something. How do I fix it and what does it mean?
The F3 code means that the temperature sensor in the oven is not giving the signal to the oven control. This could be the result of a problem with the wiring or the wire harness between the control board and the sensor or indicate that the sensor itself has failed.
To identify the correct parts, you need to provide your oven model number. Try here: http://www.partselect.com/Magic-Chef-Parts.htm . There are other sources for parts.
I hope this helps. If you add a comment with the model number, I'll be glad to give you more specific information for your wall oven.
Sep 25, 2011 | Magic Chef Ovens
I have a magic chef S68-3cxw electric stove/oven. It is flashing f2 can anyone advise what F 2 stands for
Hi, the F2 code on the Magic Chef Oven implies that the Oven temperature is too hot.
The solution is to replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness...
Oct 09, 2010 | Magic Chef Ovens
Magic Chef oven does not work but all burners do
25 yr old oven...........so I bought a new one with a few blemishes for $200.
Apr 04, 2010 | Magic Chef Ovens
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
Sep 13, 2009 | Magic Chef 9815 Electric Single Oven
I have a majic chef oven, when i turn it on it beeps and flashes
Self clean on some older models can cause some issues. F-3 is a sensor error. This could have been damaged by high heat or in some cases if the sensor is ok, the control doesn't know it's there.
Mar 14, 2009 | Magic Chef 9815 Electric Single Oven
My magic chef oven will not heat in the oven or on the stove top after the electricity was shut off for a few hours. what could be the problem?
If it has a timer, make sure it is set to manual,and not flashing auto.
In the auto mode the oven will not work.
Plz rate this solutioin.
Thanks.
Dec 27, 2008 | Magic Chef 9512 Electric Single Oven
Magic chef oven wont turn on
yes oven ignightor to confim this try broil if it lights then its bottom oven ignightor get back wit me ill outline procedure
Dec 29, 2007 | Ovens
Magic Chef Oven won't light
Your oven bake ignitor is becoming defective. Even though it is glowing, the resistance is not great enough to "pop" the gas valve open and is slowly seeping gas into the oven cavity. With a strong ignitor, the oven should light within 30-45 seconds. Because this is a gas oven, I DO NOT RECOMMEND FIXING IT YOURSELF. Call an experienced technician.
Sep 27, 2007 | Ovens
Ovens Logo
950 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
