Question about Mercury P4VM800M7 Motherboard
Beeeeeeep beep beep beep
Yes, 1 long 3 short. was playing wow and went to ope a program and the pc went into a reboot spin. p opened the case and cleaned it and now no video and 1 long 3 short beeps
  • DJLUNATIK Jan 03, 2009
    I Have the same Problem but I dont have one long beep first its Just three beeps and they do not stop they beep three times and just keeps repeating.. No Audio and I do have an ON-Board Graphic Card... I opened the case and was Updating the Memory and Decided to Blow all the dust off the motherboard and went to boot and the BIOS beeps started... What Can Be done to fix this?? I tried pulling the MOBO b/u batterie...
  • total_eclips Feb 25, 2009
    i get the same 1 long beep followed by 3 short beeps on reboot and sometimes have to completely cut the power to get signal to my monitor when this happens. no problems if i leave the system running and idle. i cleaned the tower and made sure the video card was secure and still the same issue. all trouble shooting steps produce no problem. advice?
  • 23 Answers
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
141
Posted on Mar 08, 2009
    Problem Solver:
  • 17 Answers
For some strange reason the moment you open it up and clean a pc thats been working fine for a while, it gives problems! I know its happened to me as well :)
The beep scenario you mentioned is usually when the graphic card fails, but it might be that you have not fixed it properly back into its slot (assuming its not an onboard graphic card). If its not an onboard what you can do is take the graphic card blow any dust that might have got into that slot, and also take some perfume or similar item (that evaporates quickly in air) and clean the gold contacts, keep it for a while to evaporate any liquid and then reinsert the card and try.
If the graphic card is onboard the problem can be very different!
Posted on Dec 11, 2007
Land cruiser alarm
check the water level in the radiator
possible a low water alarm
Nov 18, 2017 | Toyota Land Cruiser Cars & Trucks
Blank screen and continuous beeps when computor starts up
Count the beeps, they tell the technician what is going on. Normally that is a pattern to the beeps such as (3 long beeps, 1 long beep followed by two short beeps).
Does the laptop post anything on the screen when you hit the power button or does it immediately start beeping?
Just off the top of my head I would think you've got a memory issue. It could be a Video Card issue too.
What brand and model is your laptop?
Lets, try the memory tests just in case:
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 03, 2012 | Advent Computers & Internet
My compaq presario sr1000 computor won't stop beeping from the inside and it says no signal on the monitor
1 short beep and 1 long beep means its a memory problem.
Shut down your computer, then open your computer case and replace the memory module.If you have 2 or more modules ,try starting the pc with one.If it fails, try a different single module.
2 short beeps and 1 long beep repeating for 5 times means its a graphics card issue.
Shut down your computer, then open your computer case and unplug the graphics card, then plug it again.If this doesn't help, try with a different(confirmed working) graphics card.
Mar 13, 2011 | Computers & Internet
Had plug and play config f1 f2 error message problem. replaced battery message went away but can not boot up
boot to BIOS Press ALT+E (1 Beep) Press ALT+F (1 Beep) Press ALT+B (Reboot)
see what happens
Dec 14, 2009 | Dell Dimension 8200 PC Desktop
One Short beep and two long beep
The beeps you hear are BIOS Beep Codes. Sort of like a Morse code, if you know what that is. Every computer has it's own BIOS program, and version of that program. Each BIOS has it's own Beep Codes.
Taking a guess, as I don't know what BIOS program or version you have, it sounds like a ram memory issue.
Suggest you,
1.Unplug the computer
2.Open the computer case
3.TOUCH the metal frame of the open computer case, to relieve you body of Static electricity. Static will silently fry out your delicate computer hardware components. You won't see it or feel it.
4.Remove the ram stick/s. Reinstall the ram stick/s. (Stick/s means one ram stick, or two, three, or four ram sticks)
You may have just had a loose ram stick.
Apr 28, 2009 | MSI KM2M Combo-L (MS-6738-010) Motherboard
Dell dimension E310 crash
  • Bad video card - 1 long and 2 short beeps
  • Bad power supply - 1) continuous beeps, 2) non-stop short beeps
  • Bad memory - 3 short beeps
  • Bad Motherboard - 1 long and 1 short beep
  • Disk drive related problem / Video card problem - 1 short beep then nothing happens
May 02, 2008 | Computers & Internet
Video problems with wow
Sorry, but you need to provide more details about your system before a relevant answer to your question can be posted.
  • Is this a persistent problem? Does it happen after rebooting? Every time you play WOW? When did the problem first occur? Does it happen when WOW is the only program running? Etc.
Dec 16, 2007 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Dell optiplex Gx 150
This is a problem with your memory.
During POST, the computer checks the computer's memory, determines the amount of installed memory, and then writes to and reads from the number of available bytes to ensure proper operation.
Basic Checks:
  • If an insufficient memory message appears, save and close any open files and exit any open application programs not in use.
  • Consider installing additional system memory.
  • Run the System Memory test in the Dell Diagnostics.
  • Reseat the memory modules.
  • Restart the computer.
If the problem still exists after you complete the basic checks, fill out the Diagnostic Checklist as you perform the following steps.
caution.gif CAUTION: Before you perform this procedure, see "Safety Information."
  1. Reboot the computer.
Does the RAM count displayed correctly match the actual amount of memory installed in the computer?
Yes. The computer needed to update the memory count. The problem is resolved.
No. Go to step 2.
  1. Run the System Memory test group in the Dell Diagnostics.
Did any of the diagnostics tests fail?
Yes. Contact Dell for technical assistance.
No. Go to step 3.
  1. Turn off the computer and peripherals, disconnect them from their electrical outlets, wait at least 5 seconds, and then open the computer cover.
  2. Rotate the power supply away from the system board.
  3. Replace the memory module(s).
  4. Close the computer cover, reconnect the computer and peripherals to their electrical outlets, and turn them on.
Yes. The memory module(s) were defective. The problem is resolved.
No. Contact Dell for technical assistance.
Nov 06, 2007 | Dell OptiPlex GX260 PC Desktop
Wont even load onto bios.
you could be right but it's hard defining beeps but i would reseat your memory and graphics card as 1 long and 3 short beeps refers mainly to graphics
Aug 28, 2007 | ASUS A8N-SLI Premium Motherboard
Mercury P4VM800M7 Motherboard Logo
376 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
