Question about Frigidaire FRS26ZSG
FRS20zrgw3 side by side fridge freezer. The wall between the fridge and freezer has been very hot for a while but no issues with the unit. Now the unit has had freezing issues in the freezer. I have replaced the defroster thermostat and the timer with no avail it still is not working. What now the unit si 9 years old and I do not have the $$ to replace so hope that I can fix
  • 4,066 Answers
Check condenser fan underneath where the compressor is.
Posted on Sep 13, 2009
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Jul 10, 2016 | Refrigerators
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
My whirlpool reftrigertor side by side, fridge side is hot and the seals are extremely hot. I just bought it today at a tag sale, it is only a year oldm, what can the problem be?
If the cooling is OK specially in the freezer and the fridge, then you need not have to worry on much. If there is no cooling then the unit must be checked for failure in the sealed unit.
However you can select a NORMAL thermostat setting for the fridge /.freezer , set it lower than the present settings. Also check and see if the unit had the panels removed, if so the insulation of the heat exchange coils could have come off and it might be heating the side metal wall of the fridge.
The heating of the coil is quite normal as due to the heat exchange needed for the cooling.
Jul 28, 2011 | Whirlpool Refrigerators
The side wall of the fridge and the wall betwen freezer and fridge is hot, very hot.
clean the coils and make sure the fan by the compressor is running fast enough . this will cause the unit to run to hot if dirty and the wall between should be hot it has a hot tube running through it .. but if comp is too hot so is the wall ..mm
Aug 10, 2010 | Daewoo Refrigerators
Divider between the fridge and freezer is hot to the touch, only from the outside the inside walls of both the freezer and fridge is cold, but the outside facing you as you open the door divider is very...
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
Jun 03, 2010 | Kenmore 53642 / 53644 Side by Side...
Hot plastic smell and the wall between freezer and fridge is very
This is most likely due to an overheating condenser. I have put together some instructions on how to check and repair this. Follow the link below and let me know if it helps.
http://www.fixya.com/support/r4694132-hot_door_seal_rail_divider_strip_between
May 11, 2010 | Samsung RS2630SH Side by Side Refrigerator
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
Wall between fridge and freezer is very hot
I understand you are a little irritable about your Maytag. If you would like the service manual or one on one help free free to let me know. Your refrigerator is a complex refrigerator. But quality is Maytag. They are the only company that I know that will go out of the way to insure their customer is satisfied. If you would like the service manual or personal assistance, please let me know, Sea Breeze
Jul 11, 2009 | Maytag MZD2766GES Side by Side...
Refridgerator top freezer exterior wall hot
Hi.........
Folow these steps. It's worth a try.
1.Pull the fridge out from the wall and unplug it.
2. Clean the dust and lint off the compresser and everything else.
3. Also clean under the fridge.
4. The frame around the freezer door should cool down.
If the cooling fan was stuck , that may also be a cause for your refrigerator wall becoming hot.Check that too.
Hope My info is useful....Bye
Sep 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Maytag side by side fridge.
My Maytag side by side is 7 years old. Bar between fridge and freezer just began getting very, very hot also? What can we do to repair? Does the condenser fan motor need to be replaced?
Oct 23, 2007 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
137 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
