Question about Garden
Clippings not going into catcher...dropping onto lawn
Our lawnmower has just recently started only filling the bag about a 1/4 full and then it starts dropping big clumps of clippings onto the ground. I was advised that the bag may be dirty...so I washed it out and that perhaps the blade was on incorrectly. I know this is a stupid question but...should the beveled edge of the blade be facing the lawnmower deck or the ground? I have tried to find something about this on the internet and from what I've read - the beveled edge should be towards the lawnmower...is that correct (that is how the blade is on the mower now)? I tried to mow again today, but I am having the same issue...bag not filling - the mower dumping in clumps on the ground (under mower as it goes along). I have even tried to go back over the clippings but the same thing keeps happening...what am I doing wrong or what is wrong with our lawn mower??
  • jdmckay13 Sep 13, 2009
    I have scraped the underside of the deck and the hole that leads to the bag and it doesn't seem to have made any difference.
  • 474 Answers
Ck the outlet of the deck and any connection between the deck and bag for debis build up.
Posted on Sep 13, 2009
Looking for catcher to fit
Instead suggest a mulching blade.
Check to see that the earthworm population in your lawn is healthy.
They will eat the clippings and create castings fertilizer for your lawn.
Most earthworms come out at midnight to feed.
Feb 17, 2016 | Garden
Why do the clippings remain on lawn and don't enter bag?
Blades cut the grass and blow air like a fan. The clippings should flow along with the air out into the yard or into the bag. That only works if the bag acts like a filter and catches the clippings but lets the air out to be replaced by more air and more clippings until the bag is full of clippings.
The most likely problem is that your bag does not let the air out. Cutting wet grass will coat the inside like green paint. When dry, it's like the underside of your mower.
Check the inside. You might need to scrape and/or flush from the outside in. Can yours be turned inside out"? That would be the best case.
When clean and dry, it should work.
Didn't mention the easiest fix: to take out the hand-ful of clipping blocking the path to the bad: since you already checked that.
Aug 31, 2014 | Garden
Toro personal pace 20372, starts fine, runs well for 30 or 40 minutes then dies. Starts up again when cooled down just a bit.
Need fuel that is not more than a couple months old
Need a good or clean spark plug
Have no idea how old it is, or how many years
you have used it
Sometimes you have to remove the head & clean the
carbon off the piston & head
That is a tune-up on small equipment
Make sure the air filter is clean
They usually start with the air filter off,but you don't
want to do that all the time
Jul 21, 2014 | Toro 20372 Recycler Personal Pace...
Masport Morrison parts manual for 1995-1996 lawnmower? motor is a Briggs and Stratton 3.5hp 10A900 series
find the model # and type on the crown of the pull started (there stamped in.
Go to Briggs&Stratton Parts
Nov 08, 2013 | Garden
I need a grass box
WHAT IN THE H..... IS A "GRASS BOX" DO YOU MEAN A CATCHER BAG FOR CLIPPINGS????
#1 IT IS MUCH BETTER FOR YOUR LAWN TO LET THE CLIPPING FALL INTO THE GRASS, AS THEY DECOMPOSE...THEY FEED AND GIVE NUTRIENTS TO THE SOIL
Jul 30, 2012 | Garden
Lawn mower wont pick up the clippings
if you have ever mowed your lawn when it was wet, you might have formed a clog in the pipes to the clipping catcher. Make sure that the mower is OFF (so you don't chop off your hands) and take a look at the bottom of the mower -- if there is a lot of grass stuck there, you probably have a clog. Clean out the grass from the bottom of the mower, and remove the bag. Make sure that the opening from the base of the lawnmower to the bag is totally clear and give it another shot.
If it is not this, are the clippings just clumping up on the ground as you mow the lawn? or are they being thrown around the yard like they have no direction as to where to go?
If the connection between the mower and the bag are clear, and the grass is just clumping as you cut it, there might be some sort of blockage that you did not notice, keeping the clippings from going where they are supposed to. Make sure you have your bag hooked up properly, and that the clippings have a clear path to the bag. If there is still no love on it, you will probably have to see a repair professional so they can give it a good look (it's tough to resolve complex issues over the internet).
If the grass is not clumping when cut, but is being tossed in all directions instead of being directed to the bag, then you will have to take it in for service -- this would seem to indicate that the mower blades have somehow become distorted and the air flow that you need (to direct the clippings) is not being directed properly. A professional repair person would have to have a chance to see the mower in action to find out what is wrong (once again, it's difficult to fix something you can't see). Good luck ... hopefully it's just a clog (it happens to me all the time).
May 29, 2011 | Toro Power Lawn Mower
My 22" cut toro lawnmower with its 190cc Briggs & Stratton motor with automatic choke starts easily when cold and runs well. When you turn it off to empty the grass clippings bag, it will not restart...
You may want to check valve clearance, sounds borderline. You should have 11/1000s on the exhaust valve.The exhaust is usually the culprit, since it runs hotter.
Oct 05, 2010 | Toro Lawn Mower With Toro Power Tools
Rear mounting grass catcher has space along bottom where all the grass gets out. Yes the side shooter is closed. Yes the top door over the catcher is closed. Yes, it's hooked onto the only place I can...
grass will build up over time on the underside of the deck possibly impairing the flow of the clippings. I use a flat screwdriver to scrape the big clumps of grass off the underside.
Jun 13, 2010 | Poulan Pro 22" Self Propelled High Wheel...
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Jun 10, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
My lawnmower won't start
My first action would be to check for fire. Pull the spark plug wire and either snap an extra plug onto the wire, or pull the mower's plug and snap into the wire. Pull or try the key start, to see if the plug is firing.
If it's not firing, you'll have to look at other possibilities... eg kill switch or coil issues.
I hope this helps... Good luck!
Oct 22, 2009 | Garden
Garden Logo
216 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
