Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I've lost the master key for my dsc pc500rk keypad
I've just moved into a new house. It has a DSC PC510 with a DSC PC500RK Keypad. The one problem is that the esate agent didn't give me the master code. How do I reset it and are can you use the default codes like 0550 or 1234?
    President:
  • 3,197 Answers
You can go to this website and get an owners manual.
Posted on Sep 14, 2009
  • Don Maggard Sep 15, 2009
    Oops I forgot to give you the website.
    http://www.gcsecurity.com.au/panels/
My DSC Wt5500 Alexor Wireless keypad not keeping correct time even after changing batteries. Is there something in the programming I need to do to get it right? Thanks!
I am assuming that the keypad was successfully enrolled? Try to reprogram time. Time should be coming from the main unit and not the keypad itself.
*6
Master Code
24 hour time (ie 2pm= 1400)
Date Format mm/dd/yy
Keypad should confirm successful entry by beeping rapidly three times
press # a couple times to get out of programming
After exiting programming the display should come up within 30 seconds or so displaying the date and time before it goes back to sleep.
Apr 12, 2015 | DSC Wt5500 - Alexor 2-way Wireless Lcd...
Dsc pc1550 keypad charms do not work. When we open door or windows no charms noise at keypad.
Is there a chime button on the keypad? If so, press and hold until you get 3 confirmation beeps. Approximately 2 secs.
Nov 02, 2014 | DSC PC1555HS PC1550S SMALL CAN PC1550
How do I reset code on dsc
*5
Master code
Enter 40 for new master code
Enter new code twice
Keypad will beep three times rapidly confirming successful entry
Press # a couple times to exit programming.
Aug 26, 2014 | DSC Alexor Alarm System Wireless Panic...
HOW TO CHANGE MASTER CODE DSC PC2550RK
You need the installers code (default is 2550). To change master code, enter the following:
[*] - [8] - [Installer Code] - [2] - [5] - [New Master Code] - [#]
Jun 24, 2014 | DSC Pc2550rk Pc Classic Pc2550 Rk Keypad...
How to reset pc3000rk keypad
go to the following link below and see the door chime setting. switch it off as instucted in the manual and it should sort out your problem.
http://www.myalarm.com/manuals_prog/pc3000p.pdf
Oct 25, 2013 | DSC Pc3000rk Pc Classic Pc3000 Rk Keypad...
I needed to know how to change the time because it will be daylight savings time change tonight.
Cut and Paste this link it will tell you all you need to know
http://www.dsc.com/index.php?n=products&o=view&id=6
Mar 12, 2011 | DSC MAXSYS PROGRAMMABLE MSG LCD KEYPAD W/...
Reset master code
The only way to reset the master code is with the installer code, which is generally set by the installing alarm company. I believe the default installer code is '5555'.
Mar 07, 2011 | DSC MAXSYS PROGRAMMABLE MSG LCD KEYPAD W/...
Just moved into new house. Plugged in DSC PC1832 to power outlet. Keypad beeps every 3-5 seconds and yield sign is lit. How do i keep it from beeping, and only beep when doors open?
This means there is a fault on the panel, either something very benign ( like the system clock is not set or a low system battery ) all the way up to a major configuration or communications problem. You can press * + 2 to see the troubles on the panel. If it is the system clock, you can set it from there and be home free. It is probably a good idea to have the local alarm company come by and do an inspection and test, though, as the communications may be down ( last tenant ended the monitoring contract, phone line may be disconnected, etc.) and you probably want to change the user codes.
Jan 03, 2011 | DSC 8 Zone LED Keypad
Need operating manual
http://www.paradox.com/Documentation/Manuals/ARCHIVES_UserQuick/SPEKEU-03.PDF
See if that helps. Let me know if you need a new panel/keypad. I have DSC 1616 Power series.
Stewart
May 30, 2010 | GE Security Simon 3 Wireless Home Security...
I need an instruction manual for a DSC PC500RK home alarm system
try elitezoom.com or safemanuals.com they may have 1
Aug 26, 2009 | Home Security
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,397 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
