Question about Creative Labs ZEN Vision:M Digital Media Player
Firmware problem..... Anyone get my comment??? I lost the firmware to my zen vision:m and I am having problems loading it???
    President:
  • 4,402 Answers
Try different usb port and different computer
could also have loose connection on usb port on the unit.
Posted on Dec 12, 2007
Zen vision m 30 g, firmware terhapus gimana
you can go to the Creative Website and download the latest firmware.
and the desktop software.
when you mount it on the computer you will be able to restore the software/firmware.
there are options in the players menu for rebuilding database and things before you restore to see if that helps.
Apr 30, 2009 | Creative Labs ZEN Vision:M Digital Media...
Zen vision 30 gb front buttons don't respond
Go to the Creative website and D-load the firmware renewal utility for your player. It should detect the player via USB automatically and find the firmware for it via the Internet connection. No buttons required.
Jul 31, 2008 | Creative Labs Zen Vision Digital Media...
Zen vision m firmware problem
Greetings,
Lotsa people are having the same problem with the firmware updates. Go check for your warranty, the product was working fine before applying THEIR firmware update.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 28, 2008 | Creative Labs Zen Vision Digital Media...
Firmware problem for zen vision M
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 25, 2008 | Creative Labs ZEN Vision:M Digital Media...
I had the same issue with my zen vision m. It was not recognized on any computer (although it would charge) and I noticed that when I turned it on after having it off for any amount of time, the zen would rebuild half way before turning on.
If this is what is happening with you, then this one solution I found to fix it:
Download the MP3 Recovery Tool from Creative Support website. Make sure that your Zen is charged at least half.   Turn on your Zen, Holding the power switch in the on position (Very Important!). While holding the Power switch on, Reset the Zen by inserting a small object in the Reset hole on the bottom of the Zen (small objects can include thumbtack, wire, earring, etc...). You will see a menu: Clean Up, Format, Reload OS/Firmware, Reboot. (It is now safe to stop holding the Power switch) I decided to go down the list until something worked.  I ran Clean Up first and that didn't work for me, so I tried Format.  It will remove all of your data. Once Format runs, Reboot the MP3 player and plug it up to the computer. Run MP3 Recovery Tool. The firmware should should install itself on your MP3. Once installed, your computer should recognize the Zen.
I hope this helps!
Jun 24, 2008 | Creative Labs ZEN Vision:M Digital Media...
My zen is freezeing
1. I'd try a system clean up first (instructions below)
2. definitely upgrade your firmware (http://us.creative.com/support/downloads/)
3. If all else fails, back up all your music on your PC and format it (instructions below)
.... from Creative's site
Reset, Format or Clean Up a Zen Vision:M If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
Press on the Menu/Back button on your player, and select System, and then Reset.
To Format or Clean Up Zen Vision:M
  1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off. If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. vision_m_reset1.jpg
  4. Release the Power switch when the Creative logo appears. The Recovery Mode appears:
    • Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
    • Format All (Formats the players hard disk - Note: all contents will be lost)
    • Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
    • Reboot (Reboots the device).
  5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
Jan 05, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Vision W problems
i would make sure you have the latest firmware loaded.
Nov 27, 2007 | Creative Labs ZEN Vision W Digital Media...
Zen Vision
It could be anything. Check the firmware on the device? Is it a 1.xx.xx or a 2.xx.xx? What version of Windows do you use? Do you have Windows Service Pack 2? Etc? It really could be anything.
Oct 24, 2007 | Creative Labs ZEN Vision:M Digital Media...
Zen vision m 60 Gb dont want to be charging
Upgrade the firmware to version 1.62.02. That should solve all your problems. Go to www.creative.com to download the firmware.
Sep 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs 30GB Zen Vision:M
To put songs on your creative, just use the software that came on the cd. If you don
Jul 18, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
32 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
