Question about Hoover U6616-900 WindTunnel Bagless Upright Vacuum
Belt Keeps Coming Off
Belt keeps coming of motor shaft when shutting down or pressure is applied on roller in low carpet setting while operating. I placed belt back on and all seems to be in line but when I close it up and start operating it it works until I set it on low carpet or shut it off and then turn back on...any solution would be apprecitaed.
  • 430 Answers
Replace the belt with afresh, proper sized one. Yours is stretched. It will be shiny on the underside. hoover belts are meant to fit snug. Check the bearings on the end of the brush roll to remove dirt and thread. The proper belt will need to be stretched into place using the brush for leverage. Likely that your low carpet is more dense causing enough drag to throw the stretched belt.
Posted on Sep 13, 2009
The main belt on my hoover model u6634-900 windtunnel keeps comming off the motor shaft
  • A list of things to check (unplug vacuum FIRST):
    1. All contact surfaces for belt are clean of build up, that can push belt in one direction
    2. Brush roller is not flip end for end (the pulley on the motor shaft should line up straight with the worn area of the brush roller).
    3. The guard on the bottom (covering the belt and brush sides) is clean and free of build up.
    4. The ends of the brush roller are free of build up and the bushings that slide in the end are inserted in the correct direction, this can cause the brush roller to set at an angle and cause the belt to slide in one direction.
    5. You have the correct replacement belt, I have found the wrong belt placed in the packaging for my vacuum at the factory once before (check manufacturers website).
    6. If the brush roller is extremely worn, it could be time to replace but this is very unlikely.
    7. Rotate the motor shaft by hand and see if there is any wobble, the pulley could be on crooked or bearing has failed causing slop in the motor shaft.
Jun 21, 2014 | Hoover Vacuums
I have a simplicity 7350 vacuum. The belt and roller have recently been replaced. It runs fine on floor mode and has no problems with suction. When I put the vacuum in carpet mode, I do not hear the motor...
the motor spins around a steel shaft that sticks out on one end, and the belt is driven by that shaft, belts are easily damaged and broken, meaning roller wont spin. Often a burning smell of rubber is noticed after motor shaft spins on stuck belt. cause is always hair./string/something at the three contact points. motor shaft and belt, roller and vacuum body become clogged. become familiar with taking cover off roller/belt, and cleaning Checking moving parts roller/belt come out easily and simple to clean...keep spare belts.
Mar 10, 2014 | Vacuums
Belt falls off Dirt Devil upright
I have a Hoover canister vacuum it works great.
I think you have the right idea. Good Luck!
May 15, 2017 | Vacuums
Belt keeps coming off- Dirt Devil Breeze Cyclonic Bagless Upright Vacuum
Turn it upside down and switch on the power briefly to see what happens to the belt while running. Some vacuum cleaners have a wire guide of some sort to keep the belt running true, but yours may not have it. The end of the brush roller that connects to the belt could be worn uevenly, causing the belt to ride off the motor shaft. The motor shaft might not be parallel to the brush roller.
Jan 18, 2014 | Vacuums
Hi There,
Most likely 1 of 3 problems.
1. The belt is stretched and so is just slipping off
Solution change the belt
2. THe brush roller has siezed bearings so brush cant turn properly so belt is slipping off the shaft.
Solution - check see if roller turns easily by hand if not change the bearings.
3. THe motor has twisted in its body due to cracked housing or worn rubber seats.
Solution- Depending on your skill and age of vacuum replace the housing or the vacuum.
If you need parts for your vacuum visit www.vacuumspot.com.au
May 13, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Oreck vacuum is smoking and the roller is not turning. vacuum is turning on and inflating well.
Sounds like the roller is jammed up. The motor keeps driving the belt, but for some reason the belt cant drive the roller. The smoke is coming from the belt, Clean the junk out from the roller.
Oct 09, 2010 | Oreck Vacuums
Belt keeps breaking.
your brush roller isn't turning unplug the vacuum and see if you can turn the brush roller and also notice if it turns freely or is it stiff,take the roller out and remove strings,carpet strands and hair.if you can pull the ends off clean the ends good and maybe add just a little drop of machine oil on the bearing on the inside the roller where the bearings are.clean the motor shaft.there is probably old burnt rubber on the motor shaft.you can use a pice of emery cloth ,clean it till you see the polished finish .but i would say your problem is in the brush roller and the motor shaft.i hope i was some help to you.can you please leave some feedback
May 03, 2009 | Kenmore Whispertone 29512 Vacuum
Hoover Wind Tunnel - Belt Keeps Coming Off
This is the same problem I had. We took it to a vacuum repair store and they fixed it for $80.00!! It lasted about 6 months and it just happened again. I'm not spending the money - I'm looking for another vacuum cleaner.
Apr 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt Keeps slipping off shaft
If this is a new belt that keeps coming off, then if not catching something in the roller like a scatter rug, etc then the belt isn't tracking true. The pulley may have come loose for one thing, something has to be off to have the belt come off. Does it come off almost right away, or after some uasge?
Sep 27, 2008 | Hoover U6434-900 Bagged Upright Vacuum
Hoover U6616-900 WindTunnel Bagless Upright Vacuum Logo
234 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
